kgb Posted November 12, 2012 Report Share Posted November 12, 2012 I want to do fixed plastic windows on the rear doors. Its time to make my car water proof. I had two people promise that they will help, so I waited..............(one of them had this done to his car), but theyre too busy to help. Any ideas? Quote Link to comment
datzenmike Posted November 12, 2012 Report Share Posted November 12, 2012 Lexan? It's a polycarbonate resin and is stronger and harder than plexi-glass. Lexan is the same stuff used to make bullet resistant windows. In a car you can run thinner than glass and save weight. Quote Link to comment
ggzilla Posted November 12, 2012 Report Share Posted November 12, 2012 Lexan is far better, but cost more too. Plexi will scratch up easily, but no big deal for the rear door glass. It won't make it waterproof. The doors were designed to have rainwater run down inside and go out the drain vents in the bottom of the door. Quote Link to comment
erichwaslike Posted November 12, 2012 Report Share Posted November 12, 2012 plexi will shatter too.... and yellow over time. Quote Link to comment
kgb Posted November 12, 2012 Author Report Share Posted November 12, 2012 Lexan is far better, but cost more too. Plexi will scratch up easily, but no big deal for the rear door glass. It won't make it waterproof. The doors were designed to have rainwater run down inside and go out the drain vents in the bottom of the door. By waterproof I meant that I would like to able to wash the car and drive in the rain. Lexan is the best from what Ive read and is worth the cost. Right now I need to find someone who know what theyre doing and have them cut two pieces to shape. Quote Link to comment
2HIPN2LO Posted November 12, 2012 Report Share Posted November 12, 2012 It's not that hard....make templates out of illustration board or a stiff hard cardboard. Make modifications and test fit that and transfer pattern to Lexan and cut out with a saber saw. Carefully file edges and install. You can also get a "coated" Lexan or polycarbonate for scratch resistance like this; search for hard coated lexan or hard coated polycarbonate. http://www.techplastcoated.com/info-polycarbonate-clear-01.asp Are you intending to put it into your factory tracks and regulators? Tim Quote Link to comment
Leprechaun311 Posted November 22, 2012 Report Share Posted November 22, 2012 so need to measure the thickness of the stock windows, the come as close as possible in the plastic stock. (lexan will do, but shatter resistant in side windows is overkill, cast acrylic will last 2-3 years in constant sunlight, do you store your car outside.... really? all the time?) Make the template board patterns, take them to a plastics fab shop (they make POS displays for all kinds of folks,... that means Point Of Sale, not our usual POS) tell them you want that size and flame polish the edges, they'll know what you mean. Make sure the templates go into the seal, not butt up to it by using the same thickness, (or pretty close) your stock weatherstrip / seals will work fine. wish you were closer, I'd do it myself. Fergus in SOcal. Quote Link to comment
ggzilla Posted November 22, 2012 Report Share Posted November 22, 2012 What's wrong with the factory glass? It is waterproof. By waterproof I meant that I would like to able to wash the car and drive in the rainMy 510 did all that... Quote Link to comment
jputz Posted December 16, 2012 Report Share Posted December 16, 2012 So whats the glass thickness? Need to do the two side windows in my 510 and cant find any factory glass. Quote Link to comment
ggzilla Posted December 16, 2012 Report Share Posted December 16, 2012 Why don't you measure your glass and tell us the thickness? It's usually 5 mm or so. But when using Lexan you can use other thicknesses. Quote Link to comment
merlin Posted December 16, 2012 Report Share Posted December 16, 2012 someone dig out some 2 door glass and make him a deal... lexan is good for the first year then it sucks, Quote Link to comment
