510newb Posted October 8, 2012 Report Share Posted October 8, 2012 I tried searching but the majority of the results were for flared 510's and the others seemed inconclusive. Will a 15x8 +15 or a +25 fit on a 4 door 510? Coils in the rear, 280zx brakes and struts with coils and camber plates up front. All fenders are rolled. Quote Link to comment
banzai510(hainz) Posted October 8, 2012 Report Share Posted October 8, 2012 buy 7s and dont worry about it 2 Quote Link to comment
Tristin Posted October 8, 2012 Report Share Posted October 8, 2012 I have 15x8 +12s in the rear of mine. It's pretty close, but I have no rubbing issues. Quote Link to comment
INDY510 Posted October 8, 2012 Report Share Posted October 8, 2012 Must be the streched tires,, because I had to hammer the 4dr "bump" and roll the rear fenders alot, just to fit a 15x7 +0 in the back with 195/45/15 tires you would need MAD camber front and rear with stereched tires, AND 15-25mm hub adapter spacers in the front with flares/pulled fenders just to fit a 15x8 +15-25 in the front..... and no flares/spacers in the back (510's NEED staggered wheels!!!) Quote Link to comment
Tristin Posted October 8, 2012 Report Share Posted October 8, 2012 I did a light roll in the rear and am rolling a 185 tire. And yes... My 15x8 +12 does not fit in the front. I would need a small 5-10mm spacer up there to clear strut tube. I think it fit under the fender though, I can't remember. Quote Link to comment
510T Posted October 17, 2012 Report Share Posted October 17, 2012 It's a lot of work... In front you need S12 or M30 struts. 1 Quote Link to comment
Tristin Posted October 17, 2012 Report Share Posted October 17, 2012 That's hot. Quote Link to comment
510T Posted October 17, 2012 Report Share Posted October 17, 2012 Thanks Tristin, I'm diggin it too B) Quote Link to comment
Tristin Posted October 17, 2012 Report Share Posted October 17, 2012 What are those? 15x8 plus what? I'm going to be changing setups and debating how large to go. Quote Link to comment
510T Posted October 17, 2012 Report Share Posted October 17, 2012 15x8 +20 w/ 5mm spacer. I am having slight tie-rod interference and am going with spherical bearing tie rods and or shorter bumpsteers/ RCAs to get it right. Quote Link to comment
4DCYKEY Posted February 5, 2013 Report Share Posted February 5, 2013 I did a light roll in the rear and am rolling a 185 tire. And yes... My 15x8 +12 does not fit in the front. I would need a small 5-10mm spacer up there to clear strut tube. I think it fit under the fender though, I can't remember. Are you running a slotted crossmember? I would like to run 15x8 +12 with 205s. Quote Link to comment
Tristin Posted February 5, 2013 Report Share Posted February 5, 2013 Are you running a slotted crossmember? I would like to run 15x8 +12 with 205s. No slotted crossmember. I dont know how low you plan on going, but with my setup there would be ZERO way I could fit 205s. I have about 5 playing cards worth of space between my 185 tire and my fender. If this is for the 2dr. listed in your profile you can roll and pull a bit more than I can with a 4dr. but I dont see a 205 fitting with my setup even if it was a 2dr... especially with corrected camber. Someone might have done it though, but Im pretty low and I dont see it fitting. It so close in fact that my next setup will be a 175 in the rear on the same width rim. Quote Link to comment
novita1021 Posted February 13, 2013 Report Share Posted February 13, 2013 I had 15x8 +0 all around on coils all around and had light rub in the rear..front rubbed on hard bumps but I can deal with some rub lol.. Quote Link to comment
