dirtdawg Posted October 3, 2012 Report Share Posted October 3, 2012 whats up guys, hoping you can help me out I've been getting fuel in the oil and not sure exactly what has been causing it. The car is a 240z with roundtop su's I originally replace the mechanical fuel pump thinking it was the diaphragm causing the leak for gas to get mixed with oil. Thought i had fixed it with that but checked the dipstick the other day and sure enough there's gas in the oil pan, pretty much no viscosity left in the oil. So im guessing it has something to do with the carbs thats causing the problem but im not sure exactly where to start. Any help is appreciated! Quote Link to comment
wayno Posted October 3, 2012 Report Share Posted October 3, 2012 So what your saying is that after you replaced the fuel pump, when you checked the oil level it was over full again, is this statement correct? I am assuming you changed the oil and filter. Quote Link to comment
dirtdawg Posted October 3, 2012 Author Report Share Posted October 3, 2012 yeah oil and filter were changed after the fuel pump was changed. It wasnt over full on the dipstick but the level had risen Quote Link to comment
datzenmike Posted October 3, 2012 Report Share Posted October 3, 2012 If running rich enough to soak the cylinders and get past the rings it would run poorly and have black smoke out the tailpipe. The plugs would be sooty and maybe wet also. Possibly a carb is draining overnight? In the morning take the air filter off and lift the slides and look in with a flashlight. Quote Link to comment
Dime Dave Posted October 5, 2012 Report Share Posted October 5, 2012 The pump uses a spacer and if it is not used, the pump will sit too close to the ecentric the moves the lever and the pump could get damaged. This would cause fuel in the oil as you originally suspected. Is there a spacer between the head and the pump? Quote Link to comment
dirtdawg Posted October 6, 2012 Author Report Share Posted October 6, 2012 double checked and yes the spacer is between the head and fuel pump Quote Link to comment
I'm BLUE Posted October 6, 2012 Report Share Posted October 6, 2012 *check for busted carb float(s) *Bad fuel pump diaphram leaking straight into engine ( but you already replaced ) *Mixture screw(s) dialed out to far ? (not super likely but could be ) *Condition of needle/seat in carb ? ( or check if haven't in a while ) have you cleaned/tuned/sync your SU carbs lately ? What are your spark plugs telling you Quote Link to comment
datzenmike Posted October 6, 2012 Report Share Posted October 6, 2012 Any chance this is an automatic car??? Quote Link to comment
dirtdawg Posted October 11, 2012 Author Report Share Posted October 11, 2012 The carbs havent been cleaned but they have a rough tune and sync that i did. The idle is a bit high but its running fairly well. Spark plugs look fairly good if not running a bit rich. ill go ahead and check the carb floats, i havnt done that yet. And no it isnt an automatic, 4 speed manual Quote Link to comment
