h22a in a datsun
dirtyydatsun
  • Replies 10
Use F20c/F22c 6spd RWD from S2000... I believe it still spins backwards like indy was saying.
F20c has higher redline (8800rpm), more peak power(240hp/153ft-lb) F22c has more torque(237hp/163ft-lb) and lower redline(8000rpm)
Some honda guys have adapted K24 engines to the S2000 ... those have better flowing heads for even more power (300+hp)
H22 fwd don't even waste your time and money. Easy modifiable motor is the B series because of the abundance of aftermarket parts available. K series is even better because of the potential for even more power. The K series is the new B series. Even though, these are still fwd, they should stay that way and not to be put in a rwd sexy dime. F20c/F22c only if you want to put a Honda motor in.
hay bud ,......don't fret i done some fitting had one collecting dust....besides the reverse spin thing....the cooling system is the other issue you'll run it to the Honda motors like to run cool, something to do with all the secondary passage ways in the motors , but i had some flow issues............ outside of a additional electronic pump , no easy or cheap solution ..... hay it was a good idea
