bryant2482 Posted September 24, 2012 Report Share Posted September 24, 2012 would a steering box from a 620 fit into a 720? Quote Link to comment
flatcat19 Posted September 24, 2012 Report Share Posted September 24, 2012 Why go backwards? Quote Link to comment
mklotz70 Posted September 24, 2012 Report Share Posted September 24, 2012 I'm pretty sure the 620 box is bolted to the inside of the frame and the 720 to the outside......so the answer would be no if I'm correct. Quote Link to comment
datzenmike Posted September 24, 2012 Report Share Posted September 24, 2012 The 620 is a one piece column and box that can't be separated. Bolt holes aren't exact but can be made to fit. The pitman arm won't be in perfect location either. (but close) You would need to swap the 620 idler, cross bar and tie rod arms. I wouldn't. Quote Link to comment
