Seedy Al Posted June 2, 2008 Report Share Posted June 2, 2008 Hey guys, just new to the forum, thought I will post up one of my many Builds So here is my 1983 Datsun bluebird. NZ New l20, 5 speed. Bought it for a song in my opinion. Nothing to special to look at, electric windows are prolly the most pimp thing...... Anyway, the plans, Fix and small rust parts, Paint it Toyota Britsh Red, Lower it plent of my 14x8's, Oil cooler for the front, make a front lip/spook. Also, change the mirrors from the doors to the wings ANd then get a cert / wof/reg And destroy the streets Of Lower Hutt with yet another ride So pics Nothing special Just your simple NZ new 910 bluebird, non hard top, which is what i prefer Started to get stripped for paint job/panel This is where the bluebirds come to play trial Fit of the Rim Allan Quote Link to comment
Seedy Al Posted June 2, 2008 Author Report Share Posted June 2, 2008 rock and roll. Got the rims back with tires today to trial fit 14x8, with 175 65. Mean pics and the rear Mild stretch Also have skyline shocks to mock up in the back for suspention. so can work out if im going to need to cut and flare shit. Dope Allan Quote Link to comment
Seedy Al Posted June 2, 2008 Author Report Share Posted June 2, 2008 so been busy, got the wheels and suspention in the back, for some reason its sitting higher than i predicted..... so will adress that issue. But anyway, its all coming along, body is all stripped ready for panel work, so onc I have finished re assembling pies new motor in the car, I will start some work on the doors etc. Pics Im hapapy with dish, might need to gently flare the gaurds a little, At the moment, the guards are sitting on the tires. other side Negative Camber Riding Action! So, thats it for now, just need to get it lower. and the front Allan Quote Link to comment
Seedy Al Posted June 2, 2008 Author Report Share Posted June 2, 2008 quote="Seedy Al"]Just been getting the high sorted and pulled the front struts to work out what shocks i wanna be buying, so yay! Pics Should have coil ivers in it by end of the week (next week!) Allan Quote Link to comment
Seedy Al Posted June 2, 2008 Author Report Share Posted June 2, 2008 not much of an update. Have moved the car to work, and have fatted the mean springs for the rear, have good travel so should get warrent and cert. Now just looking for softer springs for the front coil overs...... hopefully find some in the week end Also got all 4 of my wheels finshed now, 14x8s rock anyway Peace Allan Quote Link to comment
Seedy Al Posted June 2, 2008 Author Report Share Posted June 2, 2008 realised I never posted these up! So I built coil overs for the front of it I think in the end they only ended up ike 50mm shorter....... maybe not enough, but will see, problem is not having any easy way of running spring holders (for the life of me I cant remeber the name for the little spings that do nothing but keep the big spring capitve) So I may need to look into lowering spings or something. Anyway, Pics and story these are factory bluebird 910 struts, and I am using Toyota ae-92 strut inserts First I cut the strut, and figured what length I wanted. I then had to get spacers made up that sit inside the shock housing to stop the insert moving around (insert is a bit smaller in diameter) Then I welded the coil sleve onto the strut housing (the sleve is pretty much what holds the hole thing together) Then, I had to firgure out a way to hold the spring at the top, so I used what nissan used and cut a bit of the side of the strut insert (I also had to drill the hole in the top hat bigger, as the toyota inserts are bigger) toyota ae92 Nissan then once that was drilled, I welded a few blobs on there to match the strut., so now the both turn together like they are ment to. Then, I had to cut the honda spring i was using (out of an 80's accord) to the right length. The problem with this spring is though is that it is may to stiff, and wont get a cert. Then that was about it. all together, it just makes it easier to run shorter shocks and wider wheels. Now I am on the look out for a softer spring for the front, to lower it and make it less stiff Allan Seedy Al's Chop SHop Quote Link to comment
Seedy Al Posted June 2, 2008 Author Report Share Posted June 2, 2008 wow, its been for ever since i updated this Basicly, I decided flares would be gay, and really hard as the rear is already to low, more rear wheels offset would equal big cuts into the center of my tires So. New Plan Running the 14x8's on the rear and 14x7's on the front, which all fit perfect. I also have all the suspention pretty much dead on, just the front still needs to 2 down about 20mm..... So given that I decided to start making this thing more japanese. So i started making a front spoiler... the plan: Make a cardboard profile of the front valence and guards where it will bolt to. Trace the profile onto a piece of wooden board, about 200x2000x10 Cut Wood with JigSaw Routor Front so wood has smooth front edge Secure wood to vehicle. Fiber glass over wood and shape up sides Make mold of product Make losts of spoilers to break Win I started by buying some cardboard, about 1000 micron think. Next, i cut that into strips Next, i used a tool we have at work for taking profiles of panels, to get the outline of where the spiler will mount to on the front valence. asI took each section, I traced it onto a piece of cardboard, cut it out, and stuck it to the car, allowing enough to have overlap to give it strength. Once that was all dont, I removed it. Pics of work done All ready Started Getting profile Tracing to cardboard Cut out peice next to panel and fully profiled So yay, Seedy Al Quote Link to comment
808DA6 Posted June 2, 2008 Report Share Posted June 2, 2008 Wow. That profile tool is cool. Never seen one before. Where do they sell them (i'll be looking online in a few anyway tho) -Brian Quote Link to comment
Seedy Al Posted June 2, 2008 Author Report Share Posted June 2, 2008 That one is a wurth Product (german) But should be to hard to get from any body shop supplyer (I work for an automotive restore place) Quote Link to comment
nismopu Posted June 2, 2008 Report Share Posted June 2, 2008 Sick ride! is that a 2l six? Quote Link to comment
CharlieBucket Posted June 2, 2008 Report Share Posted June 2, 2008 awesome build! you updated like 5 times before we even woke up! i really like how it looks so low. Quote Link to comment
fisch Posted June 2, 2008 Report Share Posted June 2, 2008 Man you have a hella good collection going here! Loving all the pics, kee it up! I didn't realize an 80's Datsun could look so good! Quote Link to comment
Seedy Al Posted June 3, 2008 Author Report Share Posted June 3, 2008 haha, cheers for the comments guys And yar The 3 datsuns I have posted are 3 of 10 cars, but the rest are toyotas, so sometimes things slow down a bit when I got something else on And yes, I realise this is just pushing what would be called a Datsun. Allan Quote Link to comment
Seedy Al Posted June 14, 2008 Author Report Share Posted June 14, 2008 ah.......... a lame update with not pics i started cutting out all the rear wheel arches etc to clear the wide rims and lowerage. So, I have cut off the origianl guard flare, and then, I cut out a fairly decent section of the inner guard out, becasue when It cambers out, it rubs. and have since started remaking it all alout flatter instead of curved, will take camera tomorrow. this thing is going to be pretty slammed Allan Quote Link to comment
