Jdm720 Posted September 14, 2012 Report Share Posted September 14, 2012 I wanna swap my engine later this year or earlier next year.. I simply want MORE POWER. I don't really have the time for an extensive build, I basically want to just swap an engine in, you know..? Soo I did a brief search in the 720 section, and a quick google search... First I was leaning towards a V6, but I'm getting the impression that this may be a bit more time consuming than my schedule (maybe even my patience) would allow for.. I then discovered it appears that a KA24DE may be a swap with minor mods, and I'd be able to use my same transmission.. Also, these engines aren't too pricey. My question is, aside from the transmission, would everything else line up..? If not, what would I have to do..? I know I need the engine, harness, ecu.. Mounts..? Or maybe there's another engine someone can recommend.. Possibly an easy V6 swap..? Quote Link to comment
flatcat19 Posted September 14, 2012 Report Share Posted September 14, 2012 Why not just swap your cylinder head? Or look for an easier to find, easier to do, cheaper alternative to the KA24DE? KA24E. Single slammer. As for a V6, VG30E. But then again, anything is possible with time, money, and a welder. Do work. Your search didn't seem to yield many results. Add "Ratsun" to your search and read on. Quote Link to comment
Sealik Posted September 14, 2012 Report Share Posted September 14, 2012 Why not just swap your cylinder head? To which head?.....I'll assume the L head One would have to rotate engine about 22 degrees the other way. 84 4x4 LZ23 Quote Link to comment
flatcat19 Posted September 14, 2012 Report Share Posted September 14, 2012 HRH did a KA head on his Z24. Quote Link to comment
Sealik Posted September 14, 2012 Report Share Posted September 14, 2012 HRH did a KA head on his Z24. You are correct sir.............................................. :D Quote Link to comment
poor-mans-720 Posted September 14, 2012 Report Share Posted September 14, 2012 sick... KA on a Z series... Is the LZ build worth it? I am also on the fence about a swap. But I am thinking SBC or 302 ford. I am turning 33's right now, with plans to go to 36's. So torque is a must. Whats the numbers on the LZ build? I know the one guy... think DatszenMike did one, and he said it is torque'y but how much, compared to say a SOHC KA? which way should one lean for the off road capabilty? Quote Link to comment
Sealik Posted September 14, 2012 Report Share Posted September 14, 2012 There was an improvement with the LZ23...over Z24 Good torque...higher revving motor But.... the 4x4 is so heavy...pulled it out and transplanted it into my 510 720 will get an L28 with SUs...or triples...keep it somewhat 'stock'.... :sneaky: Quote Link to comment
flatcat19 Posted September 14, 2012 Report Share Posted September 14, 2012 KA over LZ since you need power to move big tires. VG may be more for you if you want to keep it Nissan. If not concerned about keeping it Nissan-get what you can that will fit. Whether a Buick V6, SBC, 302, whatever. Your truck. Your money. Just finish it. That's all that matters. Quote Link to comment
datzenmike Posted September 14, 2012 Report Share Posted September 14, 2012 4x4? 36s? I'd V6 it. To keep weight down get a 2wd D21 truck VG30 and 5 speed. The 720 has a divorced trans case so leave all the 4x4 stuff alone and slide it in. Adjust driveshaft length to fit. The big problem will be oil pan clearance over your front differential. I suppose a 'Yoda SAS would solve that and give better off road clearance ... maybe you've already done this to get 33s on it? The VG has about the same hp as the DE 4 cylinder but monster torque at low RPMs. Quote Link to comment
poor-mans-720 Posted September 14, 2012 Report Share Posted September 14, 2012 @flatcat- finishing it is the easy part for me, hard part is finding the motor that i want to put in there. If i am doing EFI then i think the VG would be the way id lean. I was thinking the SBC cause of the ease of not having to deal with a ECU and all, that part is what worries me a little. Never dealt with it, and am wondering the difficulty of wiring it in? Do i have to splice it into my truck? or just run that harness for the motor to its ECU? @datzenmike- there is no clearance issues :) already did a SAS with a D44 out of a Wagoneer. Already measured and with some mods, could easily slip a v8 in there. Dont need a lot of HP but cant live without torque. Dont care how fast i go, but getting to the speed limit first, is always fun!! Anyone have a 2WD D21 for sale?? lol... Quote Link to comment
poor-mans-720 Posted September 14, 2012 Report Share Posted September 14, 2012 So my quest to find either a 90-95 D21 or Pathfinder begins. Id like to keep in Nissan, thus i shall. Looking up the computer stuff now to do the swap. Quote Link to comment
Jdm720 Posted September 14, 2012 Author Report Share Posted September 14, 2012 My apologies, I meant to type in KA24E.. As for the v6, I've no full shop in my garage, as in lack of crucial tools like a welder.. And not enough hours in my days.. Might not be practical, yet. How much easier is this KA24E you speak of...? Quote Link to comment
poor-mans-720 Posted September 14, 2012 Report Share Posted September 14, 2012 strongly urge you not to start this type of modification if you do not have a welder/friend with welder/access to a welder. There isnt a drop in motor that is just going to line up and bolt in using the same mounts and everything. I would just study up and until your ready, dont start. but be sure to state that on here. some people get offended, and upset at the number of people that start a serious mod like this and do not finish. Quote Link to comment
iron_lungz Posted September 14, 2012 Report Share Posted September 14, 2012 Sr20det maan Quote Link to comment
flatcat19 Posted September 14, 2012 Report Share Posted September 14, 2012 ^ Tyte idea, Yo. 1 Quote Link to comment
Jdm720 Posted September 14, 2012 Author Report Share Posted September 14, 2012 I finish whatever I start... I was hoping somebody would have some answers in regards to the KA24E.. So far I'm seeing that may be the quickest route, I don't wanna down my truck for too long.. Or maybe swapping the cylinder head, what was done to accommodate the KA on that Z24..? This is still in the research phase Quote Link to comment
datzenmike Posted September 14, 2012 Report Share Posted September 14, 2012 Sr20det maan Ok for 2wd light truck on the street. Useless on 4x4 that's hauling 3,600 pounds around on 33" tires. I finish whatever I start... I was hoping somebody would have some answers in regards to the KA24E.. So far I'm seeing that may be the quickest route, I don't wanna down my truck for too long.. Or maybe swapping the cylinder head, what was done to accommodate the KA on that Z24..? This is still in the research phase See HRH's thread on this. Quote Link to comment
flatcat19 Posted September 14, 2012 Report Share Posted September 14, 2012 KA is a close to bolt in affair. Whether E or DE. Keep reading. A CAN/AM box will help in getting the thing running. Icehouse sells it-and his thread is pinned to the top of the parts for sale section. No matter which way you roll, you will need to be armed with knowledge. Don't stop reading until you are waking up reciting instructions in your sleep. This will make the swap go much easier. I second to reading HRH's thread, for two factors. One for the KAZ head swap. Two, because he put a Z block into a Hardbody. Reverse the procedure to put a KA where a Z block use to be. Also follow Icehouse's KA24E to 620 thread in the How-To section. This will give you a good basis of what all will be involved. Get some! Quote Link to comment
Jdm720 Posted September 14, 2012 Author Report Share Posted September 14, 2012 See HRH's thread on this. A CAN/AM box will help in getting the thing running. Icehouse sells it-and his thread is pinned to the top of the parts for sale section. I second to reading HRH's thread, for two factors. One for the KAZ head swap. Two, because he put a Z block into a Hardbody. Reverse the procedure to put a KA where a Z block use to be. Also follow Icehouse's KA24E to 620 thread in the How-To section. This will give you a good basis of what all will be involved. Get some! I'll check these out... I saw that KA24E to 620 thread just yesterday, and am now following it.. Taking notes ;) Quote Link to comment
jesusno2 Posted September 15, 2012 Report Share Posted September 15, 2012 depending on which style ka you go with truck or 240 will detirmine how much trouble you run into. 12v ka from a 240 you will need to fabricate a oil pan lots of custom hose routing motor mounts etc. Quote Link to comment
datzenmike Posted September 15, 2012 Report Share Posted September 15, 2012 What he did was run a Z24 block in place of a KA block. Swapping heads alone won't work. A KA head on a Z24 will produce a compression of 7.47 and here's why. The KA uses a larger chamber head and almost flattop pistons. To use the KA head you would need KA pistons in your Z24 motor...... and weld up an oil drain back hole in the KA head that will open into the water jacket of the Z24 block...... and....... A good read for info on Z24/KA24 motors... http://community.ratsun.net/topic/25243-kaz24-build-thread-compression-questions-cam-header-done/ Quote Link to comment
