510 front driveshaft section
  • Replies 17
ok! well the driveshaft under mine was 2 pieces , probably modified by the previous owner ...so I assumed It was like that lol
so yes I need the part that goes in the tail of the transmission
If the driveshaft is 1 piece I would need to shorten the stock one ?
This is what I have. It is a stock length, manual trans, shaft with the trans yolk attached, so If you have a dogleg 5speed it will fit because the dogleg is the same length as a stock 4speed. The U joints still move but they were sitting outside for a while so I would replace em. let me know if this looks like it will work. 084.jpg
Post some pictures of it and the rear end. A two piece makes no sense to me. Maybe something else was changed also. The 240sx had a two piece... maybe the 240sx rear end was swapped in? A bit of a stretch but better to find out.
sorry for the delay but here you go
the rear end was the stock one so I didn't took pictures of it ...
here is the transmission ... I noticed the yoke was in there so I wont need it
length is :
and then the driveshaft
and the length of the long section ... I think I will need to modify to make it longer
so I think I have all the sections I need , but if you can tell me the lenght of a regular driveshaft that would be helpfull
I need a front drive shaft section for my 510
will be 5 speed with a dogleg transmission
This is certainly NOT a dogleg transmission. The dogleg is only 26" long, this is 31.5" and appears to be a '77-'79 620 truck, 280z or first year 280zx 5 sped. (likely a '79 zx)
The two piece driveshaft is probably from a 521 truck. It has the rear slip joint. Never seen this done before... anything's possible I guess. The left side is missing the companion part to the slip joint.
ho ! nice to know !
so will I be able to fit that tranny there too ?? do you know how long the drive shaft need to be ?
A FS5W71B in a 510 sedan. The driveshaft needed should be 37 3/8" long between U joint centers. As far as I know and to the best of my knowledge this is accurate. Have this verified by someone else.
I have another transmission but no casing ... It's in perfect condition so I hope it will fit in this case
It should. See the two large bearings on the right? If the bottom one is 56mm diameter that would be best. Also just to be sure the three shift rods should be the same diameter.
