cdub42 Posted September 12, 2012 Report Share Posted September 12, 2012 I was on my way to work today when my throttle linkage got stuck at WOT. I just created a hill and was down shifting. Blew past a cop rapping it out. Made the suicide lane and coasted into a gas station parking lot. If I was smart I woulda turned the key off but it all happened too fast. Bought a can of WD-40 and hit the whole linkage with it. And off to work I went. I'm gonna check it before I head home. Anyone recommend a lubricant for the ball ends? I was thinking a Teflon based spray. Quote Link to comment
San Maru Posted September 12, 2012 Report Share Posted September 12, 2012 Similar thing happened to me on a 280zx. An electrical connector boot fell apart, CSV plug I think, and got stuck under the linkage. It is shocking. I was pressing the clutch and then panicked as the engine RPM went way up, then I shifted to 5th. In and out with the clutch till I made a parking lot to shut it off. I would just use white lithium grease myself. Quote Link to comment
Draker Posted September 12, 2012 Report Share Posted September 12, 2012 Similar things can happen on the VG30DE(TT) scary scary stuff if you're boosting like a MF'er Gotta act quick! Cop didn't have anything to say to you? Quote Link to comment
cdub42 Posted September 13, 2012 Author Report Share Posted September 13, 2012 he wasn't paying attention? i sure made a hellova noise! Quote Link to comment
I'm BLUE Posted September 13, 2012 Report Share Posted September 13, 2012 ouch ... glad you didn't wreck. That's strange. I had that happen to me in a Subaru loyale 1.8liter (carbed) ... stuck wide open on freeway ... gutless 4wd goon though ,,, lol I simply turned it off and on to drive home the last 3 miles ... :lol: maybe kill switch for you cdub ? I like white-lithium , but there are different formula's. Not sure what it would do to the plastic rotator-cups ? (if anything at all) Silicone lube is good stuff , but has to be applied often. Teflon spray of some-kind actually sounds ideal ! Check the rotator-cups ... *occasionally* these wallow-out and fracture/spread (micro-fractures BUT they look ok) you should have (2) return springs I think .. should be fairly weak I know you know this stuff just covering bases :) Quote Link to comment
darrel Posted September 13, 2012 Report Share Posted September 13, 2012 Used to happen on my '82 turbo. The floor mat would always get under the gas pedal. Quote Link to comment
