ProsperPerformance Posted September 10, 2012 Report Share Posted September 10, 2012 I am looking for a 510 drive shaft ASAP!!! I need it to finish my 24 Hours of LeMons B210ZX project,... and I have been told that a one piece 510 drive shaft will fit my 240sx 5speed & H190 rear end... PM me or.... email: ProsperPerformance@gmail.com www.ProsperPerformance.com -AW Link to comment
datzenmike Posted September 10, 2012 Report Share Posted September 10, 2012 I've heard of a 510 sedan shaft fitting a goon when swapping a zx 5 speed in. keep us posted. Link to comment
Eagle_Adam Posted September 10, 2012 Report Share Posted September 10, 2012 ive got one, PM me Link to comment
datsunfreak Posted September 11, 2012 Report Share Posted September 11, 2012 I've heard of a 510 sedan shaft fitting a goon when swapping a zx 5 speed in. keep us posted. It's an inch short of ideal length, but it works. That's what's in my wagon. Of course now that Prosper has my diff, who's to say... :P Link to comment
datzenmike Posted September 11, 2012 Report Share Posted September 11, 2012 Yup an inch. Close enough AFAI concerned. Link to comment
ProsperPerformance Posted September 12, 2012 Author Report Share Posted September 12, 2012 Talked to Lonestar.. His drive shaft is 56 1/2 inches with spline & yolk (end to end) - WAY TOO LONG for me.... what I need is more like 46 1/2 inches (end to end) What am I looking for,.... 2 door 510?.... Any other options that will fit? HELP!!! Link to comment
datsunfreak Posted September 12, 2012 Report Share Posted September 12, 2012 Talked to Lonestar.. His drive shaft is 56 1/2 inches with spline & yolk (end to end) - WAY TOO LONG for me.... what I need is more like 46 1/2 inches (end to end) What am I looking for,.... 2 door 510?.... Any other options that will fit? Get his and have it shortened? Doesn't cost much ($100~), or take very long (2-3 days max)? I don't think you'll find one the perfect length. The 510 has the right flanges on either end, and has serviceable joints. :thumbup: Man up and cut that bitch. B) Link to comment
datsunfreak Posted September 12, 2012 Report Share Posted September 12, 2012 Also, FYI the 2dr and 4dr use the same driveshaft. The wagon shaft is even longer, and larger in diameter (reason why my wagon has a sedan shaft). As I said earlier, a 240Z shaft may work, but will most likely be too short for you. Link to comment
datsunfreak Posted September 12, 2012 Report Share Posted September 12, 2012 Wait, is his driveshaft from a wagon?!? I know he has a wagon... If it is, maybe you need to try a sedan driveshaft? Link to comment
datzenmike Posted September 12, 2012 Report Share Posted September 12, 2012 510 Driveshafts... U joint to U joint, the only way to measure. Sedan 42 9/16" Goon 48 7/8" Z driveshafts... Early... 700mm... 27.58" Late.... 750mm... 29.55" .....and I have been told that a one piece 510 drive shaft will fit my 240sx 5speed & H190 rear end... I was told Santa Claus was real too. You have a KA24E 240sx transmission and 510 goon rear axle in a B-210?... so the only way this info is even close is if someone else has done it. Stop fucking around and get one shortened. There is no easy fix for this. Install the 240sx 71C tranny and measure back to the diff flange. Make a diagram of the shaft and what and where you measured and take to the drive line shop. Link to comment
datsunfreak Posted September 12, 2012 Report Share Posted September 12, 2012 This. B) Stop fucking around and get one shortened. There is no easy fix for this. Link to comment
ProsperPerformance Posted September 13, 2012 Author Report Share Posted September 13, 2012 510 Driveshafts... U joint to U joint, the only way to measure. Sedan 42 9/16" Goon 48 7/8" Z driveshafts... Early... 700mm... 27.58" Late.... 750mm... 29.55" I was told Santa Claus was real too. You have a KA24E 240sx transmission and 510 goon rear axle in a B-210?... so the only way this info is even close is if someone else has done it. Stop fucking around and get one shortened. There is no easy fix for this. Install the 240sx 71C tranny and measure back to the diff flange. Make a diagram of the shaft and what and where you measured and take to the drive line shop. SANTA's NOT REAL?.... F-me!!! Thanks Mike,.. you just killed my inner child & Xmas is now ruined.... I'll pick up Lonesta'rs driveshaft & have it shortened... Anyone see any issues with the spline or yoke fitting my build?... Or should I ask the Easter Bunny?... Link to comment
datzenmike Posted September 13, 2012 Report Share Posted September 13, 2012 H-190 from a 510 goon and an FS5W71C from a 240sx..... driveshaft from a 510 suitably shortened and balanced... should work. SANTA's NOT REAL?.... F-me!!! Thanks Mike,.. you just killed my inner child & Xmas is now ruined.... Just have some kids or watch children at X mass. It all comes back. Link to comment
datsunfreak Posted September 13, 2012 Report Share Posted September 13, 2012 I'll pick up Lonesta'rs driveshaft & have it shortened... Anyone see any issues with the spline or yoke fitting my build?... Just keep in mind if his is from a wagon, it's a larger diameter than the sedan shaft. May have to "massage" the tunnel a bit to keep it from banging... Link to comment
ProsperPerformance Posted September 13, 2012 Author Report Share Posted September 13, 2012 Here is a pic of the driveshaft that Lonestar sent me... doesnt look much fatter than my current 240sx drive shaft. Link to comment
ProsperPerformance Posted September 18, 2012 Author Report Share Posted September 18, 2012 driveshaft puchased from Lonestar last Friday... took it to Stan Hopkins Company in Dallas today.... They cut it down, and had it ready to roll in about 2 hours... Only $80... Fits Great!,.. Looks great! Link to comment
datsunfreak Posted September 19, 2012 Report Share Posted September 19, 2012 And has the proper smaller diameter tube. Nice work. B) Link to comment
