MantisX620 Posted August 20, 2012 Report Share Posted August 20, 2012 So I needed to change my oil pan gasket and I took down the front crossmember under the oil pan. Got the oil pan all wrapped up and now I cant get the left side screw holes to line up. I tried a BFH and it didnt budge. I can get a screw in but it sits in sideways and doesnt go all the way through. Any idea how to get the crossmember to line up the way it should? Thanks all MantisX Quote Link to comment
Ranman72 Posted August 20, 2012 Report Share Posted August 20, 2012 pry bar and leverage to point to put screw in Quote Link to comment
datzenmike Posted August 20, 2012 Report Share Posted August 20, 2012 Try jacking the truck up in the middle with a piece of 2x4 under the pan... this should move the side in towards the center. Iron workers use a long tapered spike or awl to line bolt holes up. 1 Quote Link to comment
Tice Posted August 20, 2012 Report Share Posted August 20, 2012 Maybe loosen the other side, and finger tighten both sides before cranking them down? Quote Link to comment
MantisX620 Posted August 20, 2012 Author Report Share Posted August 20, 2012 Thanks guys, will try again this evening. MantisX Quote Link to comment
jesusno2 Posted August 20, 2012 Report Share Posted August 20, 2012 spud wrench datzenmike Quote Link to comment
MantisX620 Posted August 21, 2012 Author Report Share Posted August 21, 2012 Prybar worked like a champ! Thanks guys. I actually needed to pull down on it rather than hit up. Thanks again MantisX Quote Link to comment
Tice Posted August 22, 2012 Report Share Posted August 22, 2012 ^ Sweet. Couldn't find the hole? It happens... Quote Link to comment
