datsundash Posted August 12, 2012 Report Share Posted August 12, 2012 Looking at the l20b timing sets on rock auto, which brand is made in japan? They have like 4 or 5 different brands. Quote Link to comment
crackerjack69 Posted August 12, 2012 Report Share Posted August 12, 2012 I used beck arnly. It's got the 2 bright links, eveything fit correctly. Got the gasket kit from felpro. Quote Link to comment
banzai510(hainz) Posted August 12, 2012 Report Share Posted August 12, 2012 I like the Tsubaki, Japan(Cammillia is soemthing like that green box) OSK is another I dont care for the Cam sproket as much. Beck Arnely what I seen has been Japan. Do not get the Cloyes or Melling. Carquest might have the better sets Parunt or soemthing like that might be the brand. the market changes alot now as I cant keep up where they bring the stuff in from. China?Thailand??? Quote Link to comment
datsundash Posted August 12, 2012 Author Report Share Posted August 12, 2012 whats the part numbers on any of the japan made sets. Quote Link to comment
banzai510(hainz) Posted August 12, 2012 Report Share Posted August 12, 2012 just post what ones you looking at well give ou the thumbs up or down all my stuffs at home. order set for L20b Quote Link to comment
datsundash Posted August 12, 2012 Author Report Share Posted August 12, 2012 they are all shit, none of them are beck arnley. Fuck it. Quote Link to comment
john510 Posted August 12, 2012 Report Share Posted August 12, 2012 Get the Beck Arnley stuff,it will be stamped "made in japan" Quote Link to comment
Laecaon Posted August 13, 2012 Report Share Posted August 13, 2012 http://compare.ebay.com/like/261020608957?var=lv<yp=AllFixedPriceItemTypes&var=sbar OSK, $83 with free shipping. Quote Link to comment
Sealik Posted August 13, 2012 Report Share Posted August 13, 2012 Get the Beck Arnley stuff,it will be stamped "made in japan" Old stock BA cam spockets are 8 hole... All new stock is 4 hole..but.....the holes are offset as seen in pic. So...roll the dice when ordering Non conducive for checking head timing after the fact ^^^^^^ ......"The slightly used Beck Arnley cam gear is on the left...mid pic...with no notches To the right of it is the new Beck Arnley..(as I stated earlier)....notched...which can't be viewed through the 'vent' holes"........... I believe 510Freak had a TC kit for sale....made in Japan Quote Link to comment
datsundash Posted August 13, 2012 Author Report Share Posted August 13, 2012 how about this DNJ ENGINE COMPONENTS Part # TK633 Set Quote Link to comment
banzai510(hainz) Posted August 13, 2012 Report Share Posted August 13, 2012 I cant see the brite links on the chain. the other 3 the sprockets where the dowl hole is you need the inspection hole to be above it so you can see your V notch on back of sprocket and see thru it to the cam thrust plate Dash mark. notice the other 3 sets the dowl hole above it is the casting which you dont want. Not that it will not work. But EZ is better. so going by the photo the one you picked is the one I would get unless you know another site. with better photos. Alot of us ratun people bout up all the better sets years ago. also soemone might have a discount number to use on Rockauto.com so you can get it cheaper The best out of box timming kits I have seen were a green box marked CAMELIA with "Tsbaki" in samll letters underneath on the side Beck Arnely Pc together was OK as was Japan Marked OSK was OK also just the dowl hole on mine was a alittle big which mad ethe sprocket move abit before tightneing the cam bolt down. so can give the apperance of a retarded or adv cam . I just used another old style 4 hole cam spocket and it was nice and tight on the cam dowl pin. Quote Link to comment
Silky_Johnson Posted August 13, 2012 Report Share Posted August 13, 2012 http://www.joetlc.com/timing-chain-nissan-200sx-truck-p-17846.html?osCsid=dfqfurk8p3vnb6bpu63lnsq296 This is an OSK timing set. Quote Link to comment
banzai510(hainz) Posted August 13, 2012 Report Share Posted August 13, 2012 I got that OSK for 50 buck at napa thru a discount Quote Link to comment
datsundash Posted August 13, 2012 Author Report Share Posted August 13, 2012 yeah 80$ is a bit high, This is just a temp fix untill we can get the 5.6L VK fitted. OOPS. did I say that? Quote Link to comment
banzai510(hainz) Posted August 13, 2012 Report Share Posted August 13, 2012 get the 5.6L VK ?????? no 80$ is cheap then persoanlly if the sprocket is not sharp and the chain is most liley fine ZI would just buy a new tensioner and slack side guide. If its its near 40 $ for that get the whole kit Quote Link to comment
