wat Posted July 25, 2012 Report Share Posted July 25, 2012 this came in my car when I bought it, I don't know what alt this is. I don't know if it's supposed to be externally regulated or not. It's wired to an external, but there is a bunch of weird electrical wiring on this car so I just want to make sure if this is correct or not. Quote Link to comment
banzai510(hainz) Posted July 25, 2012 Report Share Posted July 25, 2012 Looks like you still have a external Volt reg so I assume you have a ext type alternator, Most wire looks intack ecpt untaped. ZHowever the guy should have used a Blck wire for the ground to the case ,so one doesnt put the ground on the + output of the alternator. Also the 2 red wires going to the starter lug. Usually there is a Fuseable link wire that is design to pop if over loaded. Those 2 wires I bet one is for the alt out put and the other goes up to the fusee box to feed it. Then the blu/wht? wire with the blu splice where does that go. If everything works you need to maybe labol them I highly recomment getting abetter oil line and put a 90 bend(elbow) near the block. Carry the stock sender also in case that Taiwan line cracks and you run out of oil in middle of nowhere The block thread is 1/8 BPT. Thats the adapter you need as most kits are 1/8 NPT. Very close but you get only about 3 turns and gets tight. Quote Link to comment
wat Posted July 25, 2012 Author Report Share Posted July 25, 2012 Looks like you still have a external Volt reg so I assume you have a ext type alternator, Most wire looks intack ecpt untaped. ZHowever the guy should have used a Blck wire for the ground to the case ,so one doesnt put the ground on the + output of the alternator. Also the 2 red wires going to the starter lug. Usually there is a Fuseable link wire that is design to pop if over loaded. Those 2 wires I bet one is for the alt out put and the other goes up to the fusee box to feed it. Then the blu/wht? wire with the blu splice where does that go. If everything works you need to maybe labol them I highly recomment getting abetter oil line and put a 90 bend(el Carry the stock sender also in case that Taiwan line cracks and you run out of oil in middle of nowhere The block thread is 1/8 BPT. Thats the adapter you need as most kits are 1/8 NPT. Very close but you get only about 3 turns and gets tight. I'm at work right no, so I will check where the blue splice goes. Thanks for the tip about the oil sender. I will find one and carry it. As for the disable links, do you know which size is needed? I cant find an amperage rating on the alt. Should i buy a few and start from small to large and stay with whatever one doesn't blow up? Quote Link to comment
DanielC Posted July 25, 2012 Report Share Posted July 25, 2012 I see a "F" and and a "N" connection on the alternator. That is a external regulated alternator. Quote Link to comment
banzai510(hainz) Posted July 25, 2012 Report Share Posted July 25, 2012 Datzenmike can help you on the fusable link part. I dont know if its really needed best to ask soemone else on that Quote Link to comment
wat Posted July 26, 2012 Author Report Share Posted July 26, 2012 Looks like you still have a external Volt reg so I assume you have a ext type alternator, Most wire looks intack ecpt untaped. ZHowever the guy should have used a Blck wire for the ground to the case ,so one doesnt put the ground on the + output of the alternator. Also the 2 red wires going to the starter lug. Usually there is a Fuseable link wire that is design to pop if over loaded. Those 2 wires I bet one is for the alt out put and the other goes up to the fusee box to feed it. Then the blu/wht? wire with the blu splice where does that go. If everything works you need to maybe labol them I highly recomment getting abetter oil line and put a 90 bend(elbow) near the block. Carry the stock sender also in case that Taiwan line cracks and you run out of oil in middle of nowhere The block thread is 1/8 BPT. Thats the adapter you need as most kits are 1/8 NPT. Very close but you get only about 3 turns and gets tight. That wire goes to the electric fuel pump Quote Link to comment
ggzilla Posted July 26, 2012 Report Share Posted July 26, 2012 It looks like a stock 240Z alternator. "wire fire to the electric fuel pump"? Quote Link to comment
wat Posted July 26, 2012 Author Report Share Posted July 26, 2012 It looks like a stock 240Z alternator. "wire fire to the electric fuel pump"? Sorry, Phone autocorrect. Quote Link to comment
