Dawa Posted July 18, 2012 Report Share Posted July 18, 2012 one of my (VERY) few disappointments with my truck is that the rear window is just too small. i was wondering if/how i could go about replacing the window with a larger one. i know 'everything has been done' and 'anything can be done with enough money.' i got to googling and found a few results: first result is Moodster's build http://community.ratsun.net/topic/32752-introduction-my-custom-620/ in which Farmer posts this photo also found this from minitruckinweb.com under mods it lists that this guy fitted a larger rear window from a king cab. so im guessin king cabs came with larger windows, alright. so my question is, have any of yall had or seen a KC/larger rear window in a regular cab truck? i still want my rear window to be able to slide so i wouldnt go exactly with a regular KC window. i take that back, just found a kc that has the sliding option i understand theyll be cutting all this metal out: and my last, maybe silliest question: where (which kinda shop) would i take the truck to have this done? auto body shop? auto window shop? thanks gents! Quote Link to comment
Jersey Posted July 18, 2012 Report Share Posted July 18, 2012 That is a very serious mod, and I would think the cleanest way to pull it off would be to pick up a King Cab cab and replace the entire back of the cab...the King Cabs look totally different than the Standard Cabs, so that's why I think it would look better to do the whole back portion rather than half. A body shop that does custom work is your best bet, I would definitely want to see pictures/examples of their custom work before I'd let them cut the back of the cab out. Good Luck! Quote Link to comment
Willdatsun Posted July 18, 2012 Report Share Posted July 18, 2012 I had no idea they were bigger on KCs ! Wow. You've taught me something ! Quote Link to comment
datzenmike Posted July 18, 2012 Report Share Posted July 18, 2012 Removing the back panel would be best because the metal just below the window is different. The back metal is corrugated and would be a bitch to weld and join together. Quote Link to comment
pharouh Posted July 18, 2012 Report Share Posted July 18, 2012 Yep. What they said. This was posted quite a while ago. The bad thing is,you can't use the stock seat any more because it would stick up at the bottom of the window. Quote Link to comment
Dawa Posted July 20, 2012 Author Report Share Posted July 20, 2012 thanks for all the info, gents! looks like if im doing this it wont be anytime in the near future. Quote Link to comment
SHORTDOG Posted July 20, 2012 Report Share Posted July 20, 2012 I have seen alot of guys do this on 720 shortbeds so it can be done and it is not all that hard. I can give you the name of a few guys i know in the San Diego area that do Kustom work and they can knock this out...no problem. They do chop tops and section cars for a living so this will be a piece of cake to them....Let me know if you want their info or if you have decided to hold off for a while. Quote Link to comment
