M240Z Posted July 8, 2012 Report Share Posted July 8, 2012 I have been attempting a coilover swap on my Z for a while now and I keep having bad luck=( I'm finally towards the end of the process and was bleeding the brakes last night. I made it to the driver side rear drum and when I opened the bleeder to let the fluid out and the shitty bleeder decides to snap leaving half of the bolt still in the hole. I got to get the rest of the bleeder out somehow, so what is the best way to do this? Quote Link to comment
ggzilla Posted July 8, 2012 Report Share Posted July 8, 2012 Use an easy-out. You can buy it at your local auto parts store. Quote Link to comment
datzenmike Posted July 8, 2012 Report Share Posted July 8, 2012 In order for an easy-out to work, make the largest hole in the bleeder and use the largest easy out that's going to fit it. Easy outs are extremely hard and brittle like glass. Quote Link to comment
MicroMachinery Posted July 8, 2012 Report Share Posted July 8, 2012 Get a new wheel cylinder... it won't be worth your time to try to get the old bleeder out, along with the frustration.. especially if you end up breaking an easy out off in there. ... holy crap. I just priced em.. kinda spendy. If you go to drill it out, luckily you have that big hole in the center to use as an accurate pilot. Just take your time, and use plenty of penetrating oil. 2 Quote Link to comment
ggzilla Posted July 8, 2012 Report Share Posted July 8, 2012 You an get them cheap. Only $57 at Rockauto.com. $40 cheaper than Nissan. Quote Link to comment
M240Z Posted July 8, 2012 Author Report Share Posted July 8, 2012 So should i try drilling it out? Once i male a bigger hole jn the middle then what do I do? Thanks for the help guys! Just looked up wheel cylinders and theyre expensive! Might be my last resort though Quote Link to comment
Laecaon Posted July 8, 2012 Report Share Posted July 8, 2012 Luck? Everybody must have this luck then. Happens all the time on these datsuns, and you never know where it will strike. Once you have a bigger hole, use a bigger ez-out. Because ez-outs are so brittle, you want to use the largest one possible for your application. Quote Link to comment
M240Z Posted July 8, 2012 Author Report Share Posted July 8, 2012 Luck? Everybody must have this luck then. Happens all the time on these datsuns, and you never know where it will strike. Once you have a bigger hole, use a bigger ez-out. Because ez-outs are so brittle, you want to use the largest one possible for your application. Yes my datsun is putting up a huge fight, but itll be worth it! And I see, i'll try it out tomorrow Quote Link to comment
MaineZ Posted July 8, 2012 Report Share Posted July 8, 2012 Buy new if you can but if not and you succeed in changing out the bleeder valve then be sure to use "never seize, or anti-seize" on the new threads. May be a good idea to do them all before you pass this road again someday. Quote Link to comment
that one guy Posted July 9, 2012 Report Share Posted July 9, 2012 Unless they're horrendously different from the 280z ones, mine was like 15 bucks... Will this work?: http://www.google.com/products/catalog?hl=en&safe=off&q=280z+drum+brake+cylinder&psj=1&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&biw=1920&bih=956&wrapid=tlif134181110958410&um=1&ie=UTF-8&tbm=shop&cid=14090963892561255293&sa=X&ei=Z2r6T-viGcqe2wWgzJWBBw&ved=0CHsQ8wIwBw Quote Link to comment
goonfan Posted July 9, 2012 Report Share Posted July 9, 2012 Get a new wheel cylinder... it won't be worth your time to try to get the old bleeder out, along with the frustration.. especially if you end up breaking an easy out off in there. ... holy crap. I just priced em.. kinda spendy. If you go to drill it out, luckily you have that big hole in the center to use as an accurate pilot. Just take your time, and use plenty of penetrating oil. This. I've "attempted" this before and it was a real bitch. $50 is well worth an hour or two of saving the frustration on the chance it will work out. Quote Link to comment
M240Z Posted July 9, 2012 Author Report Share Posted July 9, 2012 Unless they're horrendously different from the 280z ones, mine was like 15 bucks... Will this work?: http://www.google.co...ved=0CHsQ8wIwBw The ones for the 240z look completely different so I dont think it will work. I've been trying for a couple hours with a bit that locked into the threads really good......but I ended up breaking the bit. So it looks like I'm getting a new wheel cylinder. Autozone sells them for $45 Quote Link to comment
