joser09 Posted July 3, 2012 Report Share Posted July 3, 2012 hey just sold my nova and picked up a fixer uper 71 240z. i want to fit a wide rim but cant decide wiehter to go flared or leave it flareless. i love both looks, just wondering how much more room can u get with flares. and wheres the best site to buy em from. im also ordering the gc coilover sleves, to lower it a bit im also intrested in the bre lip, where can i get one? Quote Link to comment
Pasquale Posted July 3, 2012 Report Share Posted July 3, 2012 IMO it really depends. The body on my z is really cherry so cutting it up would just be a shame but if your car needs body work your going to save yourself a lot of time and money by installing the flares. to give myself the control over my camber that I needed to fit my wheels without flares I had to instal custom machined control arms and a lot of back and forth with my machinest to perfect them while I believe this is the right way to go it may not be the right way to go if you're working with a tight budget. There are way too many factors to give you a straight up and down dry cut answer. Quote Link to comment
ggzilla Posted July 4, 2012 Report Share Posted July 4, 2012 Leave it unflared, stock. You can roll the fender to get a little extra clearance without changing the classic looks or hurting the paint. You can get fairly wide tires on it, especially if they are 50-series tires they will handle very well. Quote Link to comment
jalen Posted July 4, 2012 Report Share Posted July 4, 2012 if you wanted to you could get 15x10's on a non flared z. just depends on your budget and skills. and purpose of car. Quote Link to comment
joser09 Posted July 4, 2012 Author Report Share Posted July 4, 2012 yeh im looking around for some 15x10 mesh Quote Link to comment
Alex Datsun Posted July 4, 2012 Report Share Posted July 4, 2012 if you wanted to you could get 15x10's on a non flared z. just depends on your budget and skills. and purpose of car. you need run mad negative camber unless you roll/pull and pull harder with a bit of tire stretch broham Quote Link to comment
joser09 Posted July 4, 2012 Author Report Share Posted July 4, 2012 yeh im really not sure on size actualy, ill probly choose the rims befor i paint and if theres poke ill flare. because i dont wanna massive amount of neg caamber Quote Link to comment
Aaron Datsun Posted July 24, 2012 Report Share Posted July 24, 2012 You can read my rant below but here is the general gist. You can tuck a 8.5" wheel under there with work and no flare, flaring would be easier. With stock suspension the backspace will need to be around 4" to 4.5". 15x10 will require coilovers and even still I think you would need flares. I don't have the worlds most powerful Z but she is turbo'd running megasquirt and I wanted to put wide rims on her, but decided to just re-shoe my 280zx swastika rims with nice tires and run them, the nice tires were almost as a big jump in performance as the new suspension. I think if you want to run wide rims for the look do what you want, but if you think you will never get traction just sort your suspension and bushings out, then put some nice sticky tires on them and it will handle great. Just remember a wider heavier wheel and tire will require more power to spin. I am not saying you can't find big light wheels, but if you are worried about never having traction I would say work on suspension first. Quote Link to comment
Tice Posted August 19, 2012 Report Share Posted August 19, 2012 Justin at http://zforceproductions.com/ has the best and widest flares avail for Z cars IMO. I think he also makes the BRE front. If he doesn't A simple google search will send you soaring in the right direction. Quote Link to comment
