±~~∞ Posted July 1, 2012 Report Share Posted July 1, 2012 Anyone have pictures of the OEM lug nuts off a Nissan Frontier. I realize the threads (12mm-?) are not the same as my 521 (7/16-20) , but i am not sure what style i need for this style Wheel. The guy i got them from gave me what he said were OEM lug nuts with the rims, but they are acorn style and I dont think that is correct. I think they should be the same lug nut style as what many of you have on your 521's: Pictures anyone? Thanks. Quote Link to comment
Laecaon Posted July 1, 2012 Report Share Posted July 1, 2012 I would guess acorn nuts. Do you know what that means? Because that is what the stock steelies use as well. If you look into the holes, are they tapered? If so, then that is a acorn lug seat. Quote Link to comment
mklotz70 Posted July 1, 2012 Report Share Posted July 1, 2012 the acorn is simply a cosmetic treatment. You're either going to need ones with a conical seat(nut has a cone on it).....the tapered hole referred to.....or the shank style(straight sides, no cone). Most likely, the conical style is what you need. Most parts stores will have a couple of styles. If you're really tight on money, you can get generic(Dorman), open ended conical nuts....but if you're going with those, you might as well use the stock lug nuts that are already on your truck. Aluminum rims are typically thicker.....make sure you have enough thread engagement. http://www.summitracing.com/search/Department/Wheels-Tires/Part-Type/Lug-Nuts/ Quote Link to comment
mrbigtanker Posted July 2, 2012 Report Share Posted July 2, 2012 acorn style.look in the lug hole and you will see that its tapered. Quote Link to comment
thisismatt Posted July 2, 2012 Report Share Posted July 2, 2012 There are 3 types: conical/tapered/acorn, spherical/ball-seat, or mag/flat/shank type Quote Link to comment
±~~∞ Posted July 5, 2012 Author Report Share Posted July 5, 2012 Thanks for the replies. The rims i have do have a short conical taper in the wheel which then transitions into a straight bore. The conical section is shallow and rough like it was possible it was formed by someone using conical nuts in a straight bore hole. Consensus is the conical nuts are correct, Thanks. And thanks mklotz70 for clarifying, i did mean to say conical rather than "acorn". Quote Link to comment
mrbigtanker Posted July 5, 2012 Report Share Posted July 5, 2012 I like acorn better I don't conical visits.haha Quote Link to comment
