ratsunissan Posted June 27, 2012 Report Share Posted June 27, 2012 i got new shocks and put some blocks to lower the rear end. im in the process of doing all the ball joints and tie rods and i bought some kyb's for the front. im just not to sure how to lower the front and i need some help. i heard its something with the torsion bars but im not sure on how to do it. someone help me out Quote Link to comment
nissan720 Posted June 27, 2012 Report Share Posted June 27, 2012 u can pull the clips off the torsion bars and crank them down.or u can use drop spindles.i like the drop spindles.made by bell tech or chassis tech for the hardbody but will fit 720 with the spacer kit they send with spindles Quote Link to comment
datzenmike Posted June 27, 2012 Report Share Posted June 27, 2012 Loosen top lock nut and turn bottom to adjust. Easier to do with vehicle raised. Adjust both equally and lower truck to compare heights. Bounce suspension to before measuring. You can simply turn the adjustment nuts at the rear for lowering. The C clips are only removed if you run out of adjustment and need to slide the torsion bar back to disconnect the front spline in the lower control arm. This allows you to reposition the torsion bar into a lower adjustment range and is called indexing the bar. I would avoid this if possible as lowering this amount is well outside the suspension ride height limits and the camber is badly affected. All ride height changes will also change the toe setting. Bleach said: How to Reindex Torsion Bars in front of the middle crossmember, you pull the boot forward to reviel the lock ring Work a thin screwdriver into the edge of the ring. It will be tight. I had to work the angle back and forth while occasionally tapping the back of the handle with a hammer Once you get under the ring, work it out slightly. Do not pull the screwdriver away or the ring will pop back on After you have worked it off part way, use some pliers to pull the ring off the rest of the way. Be sure to still keep the screwdriver under the lock ring Tap the rear arm of that holds the adjuster bolt out of the crossmember. Hang onto the torsion bar. It can slide out at either end. I was able to feel the splines in the end of the bar and I moved it two notches. edit:(but you only want to move it one notch!) The reindexed bar is on the right. after the bar is reindexed, just hold the lock ring up and hit the back of the ring with a hammer. It pops on real easy. Put the dust boot back Quote Link to comment
Dawa Posted August 22, 2012 Report Share Posted August 22, 2012 mike, hainz or anyone else that can answer this tried to reindex my torsion bars tonight. passenger side was fine but i couldnt remove the driver side anchor arm. i banged on it with a hard rubber mallet and then a hammer (dont have a heavy, metal mallet but ill buy one soon) that didnt work. so i took hainz approach of trying to loosen the torsion bars nut in the front @ the A arm, i loosened it almost completely and then took the hammer to the bolt, and then put a non pointed center punch on the bolt and went to town on that. didnt move a mm. also, i should add that when the snap rings were installed, the passenger side anchor arm moved forward/aft somewhat freely, whereas the driver side arm wouldnt budge. any ideas? if not then ill take a heavier mallet to it and see if that adjusts it's attitude. Quote Link to comment
]2eDeYe Posted August 22, 2012 Report Share Posted August 22, 2012 It's possible the anchor arm is rusted to the torsion bar or even the bore of the crossmember. Old trucks can be a pain sometimes. 1 Quote Link to comment
Dawa Posted August 22, 2012 Report Share Posted August 22, 2012 yeah i think thats where the problem lies, in the anchor arm itself. i was thinking this mornin on the ride into work about how i need to hit it w some penetrating oil Quote Link to comment
irishevox Posted November 21, 2012 Report Share Posted November 21, 2012 torsion bars, remove bump stops and see how it goes i know you can get a full 4.5 inch drop depending on rims and tires maybe a 5 but your camber will be soooo wild! Quote Link to comment
Smyrna720 Posted November 21, 2012 Report Share Posted November 21, 2012 2eDeYe' timestamp='1345647389' post='744089']It's possible the anchor arm is rusted to the torsion bar or even the bore of the crossmember. Old trucks can be a pain every time. Fixed lol. Quote Link to comment
