Laecaon Posted June 26, 2012 Report Share Posted June 26, 2012 oh sigh, way to mess with someone having a legitimate problem. 1 Quote Link to comment
DAT510 Posted June 26, 2012 Report Share Posted June 26, 2012 How do you do that? I wanna know how you wiped your HDD. What did you do? and what did you go with? Quote Link to comment
Guest 510kamikazifreak Posted June 26, 2012 Report Share Posted June 26, 2012 I wanna know how you wiped your Herpes Down Dood What did you do? and what did you go with? fixed Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 The tech said do a disk sanitation (that said warning will wipe hard drive) but he assured me that my is would be on there, I'm guessing he lied. So do I need to redownload a OS? And can o use a USB drive if I do? Quote Link to comment
DAT510 Posted June 26, 2012 Report Share Posted June 26, 2012 The tech said do a disk sanitation (that said warning will wipe hard drive) but he assured me that my is would be on there, I'm guessing he lied. So do I need to redownload a OS? And can o use a USB drive if I do? See if you check how much data (if any) is on the HD. Say its a 250gb disk, and you have only 200gb left.. It could be the OS. Or you didn't wipe the disk fully, and fucked with some of the OS files. If any of the above, I say use Boot N' Nuke and Re-download OS. Id get the BIOS boot order fixed first though, or else your PC will never boot. Quote Link to comment
DAT510 Posted June 26, 2012 Report Share Posted June 26, 2012 fixed I bet you're wondering too :sneaky: :w00t: :thumbup: Quote Link to comment
Guest 510kamikazifreak Posted June 26, 2012 Report Share Posted June 26, 2012 I bet you're wondering too :sneaky: :w00t: :thumbup: :rofl: Quote Link to comment
Laecaon Posted June 26, 2012 Report Share Posted June 26, 2012 What program did you use for the "disk sanitation"? Quote Link to comment
Guest 510kamikazifreak Posted June 26, 2012 Report Share Posted June 26, 2012 this always works wonders, for those pesky issues that get irritating Quote Link to comment
Hardwyre Posted June 26, 2012 Report Share Posted June 26, 2012 this always works wonders, for those pesky issues that get irritating Except the hard drive is still intact and now the dumpster diving hipster has your hard drive. But it's a hipster, and your hard drive doesn't have an apple logo on it, so you're safe. Fuck it, it was a hipster in a dumpster. He was killed by a hobo. Quote Link to comment
DAT510 Posted June 26, 2012 Report Share Posted June 26, 2012 this always works wonders, for those pesky issues that get irritating I'm pretty sure that won't fix your herpes problem, unless you want to mutilate yourself. :lol: Quote Link to comment
Guest 510kamikazifreak Posted June 26, 2012 Report Share Posted June 26, 2012 I'm pretty sure that won't fix my herpes problem, unless I want to mutilate self. :lol: fixed :lol: Quote Link to comment
Guest 510kamikazifreak Posted June 26, 2012 Report Share Posted June 26, 2012 Except the hard drive is still intact and now the dumpster diving hipster has your hard drive. But it's a hipster, and your hard drive doesn't have an apple logo on it, so you're safe. Fuck it, it was a hipster in a dumpster. He was killed by a hobo. :rofl: Quote Link to comment
I'm BLUE Posted June 26, 2012 Report Share Posted June 26, 2012 My brother threw his laptop against the wall when he had issues Works like a charm now ! True story bro I recommend you do the same C'mon whats the worst that could happen! ? Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 I went into the BIOS settings and select disk sanatation, It took 16 hours ill probably get the boot order correct and redownload the os Quote Link to comment
DAT510 Posted June 26, 2012 Report Share Posted June 26, 2012 I went into the BIOS settings and select disk sanatation, It took 16 hours ill probably get the boot order correct and redownload the os i've never heard of that... must be a HP thing.. Quote Link to comment
DAT510 Posted June 26, 2012 Report Share Posted June 26, 2012 According to HP.. Everything is destroyed on the HD So you need to redownload the OS. I think you can download the OS it originally had and enter the code on your PC. I'm not sure if HPs have the same thing as Dells, but there is a sticker on teh PC that has the code for the OS. Cracked OS's and keygen OSs are sketchy as fuck. beware. Disk Sanitizer eliminates data in every sector, every cluster, every byte, and every bit with no damageto the hard drive. Once executed, data cannot be easily recovered even when using advanced tools and techniques (i.e. file slack information, analyze data using Forensic Recovery of Evidence Device, DriveSpy, etc.) Quote Link to comment
Laecaon Posted June 26, 2012 Report Share Posted June 26, 2012 Yea you should have a "Genuine Windows" stick on the bottom of the laptop. Sometimes they are under the battery. Should have a valid key. Redownload the exact copy of windows it applies to. Quote Link to comment
jalen Posted June 26, 2012 Author Report Share Posted June 26, 2012 all the downloads i see cost money Quote Link to comment
