fo0manchu Posted June 24, 2012 Report Share Posted June 24, 2012 So here is an alternative to the more expensive setups. 280zx struts, 300zx disks and hub, 2nd gen rx7 4 piston calipers. Here is my mock setup with test brackets. This utilizes 11.1" rotors and the aluminum 4 piston calipers. Best part is I can still use 15" wheels. Although not all 15's will fit, ones where the barrels angle in will need spacers or grinding down the caliper slightly. I'm sure these calipers might work with other setups ant 11" rotors as well. Quote Link to comment
Laecaon Posted June 24, 2012 Report Share Posted June 24, 2012 What hub is that? 280zx isn't 5 lug... Quote Link to comment
fo0manchu Posted June 24, 2012 Author Report Share Posted June 24, 2012 typo... z31 300zx rotors and hub... edited now. Quote Link to comment
freekwonder Posted June 24, 2012 Report Share Posted June 24, 2012 What did you do to get the Z31 hub on. I thought you had to machine something? Any details on the adapters? Measurements, or make some more? Quote Link to comment
fo0manchu Posted June 24, 2012 Author Report Share Posted June 24, 2012 hubs just slide on. Adapters are not finished yet, this was just a mock setup to see if everything fit correctly Quote Link to comment
thisismatt Posted June 24, 2012 Report Share Posted June 24, 2012 What did you do to get the Z31 hub on. I thought you had to machine something? Any details on the adapters? Measurements, or make some more? The inner grease seals don't properly fit (smaller ID on the 300zx), but you can force them on. I'd expect they'd wear out faster, though. Quote Link to comment
fo0manchu Posted June 24, 2012 Author Report Share Posted June 24, 2012 yah, I remember reading about that awhile ago. By eye they look okay and looks like everything will seal fine. Its not a hard part to replace, so we'll see how long they last. Quote Link to comment
moath Posted June 25, 2012 Report Share Posted June 25, 2012 How thick is your bracket? I love this idea, thanks for posting it! Quote Link to comment
fo0manchu Posted June 25, 2012 Author Report Share Posted June 25, 2012 the mock up bracket is only 1/8", but only a tester to see how far i had to space it out from the original mounts. Quote Link to comment
freekwonder Posted June 25, 2012 Report Share Posted June 25, 2012 Ah ok, that's not terrible. Love the idea of the bracket. Let us know how it goes. Quote Link to comment
fo0manchu Posted June 26, 2012 Author Report Share Posted June 26, 2012 The inner grease seals don't properly fit (smaller ID on the 300zx), but you can force them on. I'd expect they'd wear out faster, though. I was taking a closer look at the grease seals and they seem to fit perfectly. I will have to take a picture of this later. Quote Link to comment
thisismatt Posted June 26, 2012 Report Share Posted June 26, 2012 I was taking a closer look at the grease seals and they seem to fit perfectly. I will have to take a picture of this later. Now that I think about it, when I compared them it was the '84 4-lug 300zx hubs, not the 5-lug, so they may be different. Quote Link to comment
moath Posted June 27, 2012 Report Share Posted June 27, 2012 Also, could you weigh the calipers? I'm curious how their weight compares to options like the Wilwoods. Thanks! Quote Link to comment
rayven14 Posted June 27, 2012 Report Share Posted June 27, 2012 Not bad at all! and you end up with a 5 lug conversion to boot? nice. Quote Link to comment
