Help 510 Drum
SpooF
  • Replies 10
Just a thought.
Did you disconnect the e-brake first? Even with mine adjusted out so the cable seems loose, it isn't enough. With new drums, it'll still catch with brand new shoes.
I fought and fought, and fought and fought, then got the wild hair to just disconnect the cable entirely. Blam, drum went on without a hitch. With the adjusters all the way out, e-brake disconnected, it's almost impossible for the drum not to slip right on over like it should.
Remember once it's back in place and you've driven it a bit, to go back and inspect them to make sure everything is going well. Re-adjust as needed. Don't adjust with the e-brake cable.
