81sunnyson Posted June 16, 2012 Report Share Posted June 16, 2012 i have a bad float on the hitachi carb and a issue with gas tank vent, cuz i cant put more than 3.5 gallons or like 15 bucks with of gas in it at a time or it will spit it out if i push down on the trunk or bumper it will open a little then gas will drain down i like that tho....its got character! Quote Link to comment
ggzilla Posted June 16, 2012 Report Share Posted June 16, 2012 First, replace the bad float. Then get back to us and report if the gas fume smells have disappeared. Quote Link to comment
datzenmike Posted June 16, 2012 Report Share Posted June 16, 2012 Where does it spill out???? Is the tank leaking?? I've had a venting problem before and the suction from the pump collapsed the tank and it would only hold a few gallons.... worse it read half full!!!. Check and see if the tank has collapsed. Quote Link to comment
81sunnyson Posted June 16, 2012 Author Report Share Posted June 16, 2012 i replaced my fuel cap with a good one from a 81 200sx.....my old one would leak making left turns got a locking gas cap from orielly's but the rubber dosent seal well Quote Link to comment
ggzilla Posted June 17, 2012 Report Share Posted June 17, 2012 Well, that's the problem then. Quote Link to comment
81sunnyson Posted June 17, 2012 Author Report Share Posted June 17, 2012 no the vent is to issue. the gas cap is resolved but haven't fixed float or tank Quote Link to comment
ggzilla Posted June 17, 2012 Report Share Posted June 17, 2012 you know what you need to do Quote Link to comment
81sunnyson Posted June 17, 2012 Author Report Share Posted June 17, 2012 the manual says stalling upon cold start is float fume front the front and the back....oh the irony Quote Link to comment
ggzilla Posted June 17, 2012 Report Share Posted June 17, 2012 There is more than one cause for stalling right after cold start You can test the float by looking in the glass sight window on the carburetor. If the fuel level is centered, the float is correct. If not, adjust the float. A bad float will cause overflowing gas into the carburetor. Quote Link to comment
81sunnyson Posted June 20, 2012 Author Report Share Posted June 20, 2012 there is gas inside the air cleaner, well on the underside of the lid it will surge real bad some days like the throttle is stuck... i tried to move the anti dieseling solenoid wires away from the manifold and that helped a little the fusesible link looks black Quote Link to comment
RedBanner Posted June 20, 2012 Report Share Posted June 20, 2012 trolling? You have many problems and you havnt answered any of the suggestions Did you look at the float window? What level does it hit while running? Quote Link to comment
