jesusno2 Posted June 16, 2012 Report Share Posted June 16, 2012 my tach in this 260 i just picked up just goes haywire, it never reads correct most the time it just stays pegged at 8k. I'm new to Z car stuff so im like a sponge right now learning all i can. Quote Link to comment
datzenmike Posted June 16, 2012 Report Share Posted June 16, 2012 Clean and gap the points. My '70 Dart would have a jumpy tach when the points were worn. You could also look for a loose connection on the coil and the ballast resistor. Quote Link to comment
jesusno2 Posted June 16, 2012 Author Report Share Posted June 16, 2012 Clean and gap the points. My '70 Dart would have a jumpy tach when the points were worn. You could also look for a loose connection on the coil and the ballast resistor. well mike its got a electronic ignition. It looks aftermarket im guessing, but still has a ballast resistor?? I'm still sorta z car retarded Quote Link to comment
Ranman72 Posted June 16, 2012 Report Share Posted June 16, 2012 well mike its got a electronic ignition. It looks aftermarket im guessing, but still has a ballast resistor?? I'm still sorta z car retarded probably petronix maybee a grounding issue Quote Link to comment
ggzilla Posted June 16, 2012 Report Share Posted June 16, 2012 280Z had electronic ignition with twin-ballast resistor (three terminal resistor). Only the 1978 had no ballast resistor. They had an aluminum box with 5 or 6 screw-on wire connections. I think 260Z had this also The coil might be wired incorrecty, that can make a tachometer jump and have a rough idle, but still make great power once it gets going. Quote Link to comment
jesusno2 Posted June 16, 2012 Author Report Share Posted June 16, 2012 Well it runs like crap at idle to about 1500. I,LLC take a picture it looks all stock to me Quote Link to comment
ggzilla Posted June 16, 2012 Report Share Posted June 16, 2012 I had this same problem coming home from Canby, where I swapped a distributor and coil. When I got home I changed the coil and all the problems went away. Funny too because at the drags, i had really good top speed. I think the problem was how the coil was wired. There is an extra wire in my harness which I didn't hook back up. but maybe that coil was bad. Since I had an extra, i swapped it in. I should have tested it with an ohmmeter. Quote Link to comment
jesusno2 Posted June 17, 2012 Author Report Share Posted June 17, 2012 pics of the coil and resistor wire that goes no where Quote Link to comment
