DAT{521}SUN Posted June 10, 2012 Report Share Posted June 10, 2012 I have an L20 I swapped in my 521 and am near completion of hopefully having the engine started, but I have reached a problem I can't seem to find the solution to. Where does the hose on the intake manifold go to? I started putting antifreeze and it started to shoot out from there. IF the solution is to simply plug it, where can I get the proper plug to do so? Thanks!!!!! Quote Link to comment
Npdavies. Posted June 10, 2012 Report Share Posted June 10, 2012 They can be plugged, but they should be connected to the pipe that comes off of your thermostat housing. It should have 1-2 smaller pipes branching down off of it, and a hose connects the intake coolant lines to that. That is, if you're talking about what I think you are. And by "should" I mean that's where they were originally. Not that they have to be there. I've heard that they can be plugged, as they are only to warm the carbs up. Not sure on that info though. Quote Link to comment
DAT510 Posted June 10, 2012 Report Share Posted June 10, 2012 What Davies said is Truth, Yo. The hose from the thermostat is meant to go in the intake. Does water shoot out of the intake?? If it does, plug the head passages, but try to run the water if possible, it helps with the air temperature, which makes it run better. Quote Link to comment
banzai510(hainz) Posted June 10, 2012 Report Share Posted June 10, 2012 What ????????????the hot water line? Does the head have water passages? Most L20 dont use them. Make sure you know what your doing. PS you pime the oil pump? http://vimeo.com/19077890 Quote Link to comment
Stoffregen Motorsports Posted June 11, 2012 Report Share Posted June 11, 2012 And by "should" I mean that's where they were originally. Not that they have to be there. I've heard that they can be plugged, as they are only to warm the carbs up. Not sure on that info though. They aren't meant to warm the carb as much as they are meant to cool it. The carb is directly above the exhaust manifold which is HOT (500-600 degrees), therefore coolant (200 degrees) running through the intake manifold actually cools the intake and helps it run better when hot. We actually tested it on the dyno (on an ITC L16) and it did, in fact, make better power with the water line hooked up. Quote Link to comment
DAT510 Posted June 11, 2012 Report Share Posted June 11, 2012 Oh and it actually comes from the water neck on the opposite side of the block, where the Lower radiator hose goes.. Quote Link to comment
Stoffregen Motorsports Posted June 11, 2012 Report Share Posted June 11, 2012 Oh and it actually comes from the water neck on the opposite side of the block, where the Lower radiator hose goes.. Right, cool water....errr coolant...whatever. Quote Link to comment
DAT510 Posted June 11, 2012 Report Share Posted June 11, 2012 I was just correcting myself, I said thermostat above... :lol: Quote Link to comment
Npdavies. Posted June 11, 2012 Report Share Posted June 11, 2012 And I was just repeating what I read off a Z forum, cause I'm leaking from those two hoses. I was thinking they would be necessary to prevent any vapor lock or backfires from the heat, but it seems the consensus is they should be left connected. Quote Link to comment
DAT{521}SUN Posted June 11, 2012 Author Report Share Posted June 11, 2012 Thanks for information! It sure did solve my problem. I should post pictures soon! Quote Link to comment
DAT510 Posted June 11, 2012 Report Share Posted June 11, 2012 I left mine off because my head's water ports are plugged, and it get hotter then hell here. It rarely dips below 20 degrees Quote Link to comment
