mrbigtanker Posted June 3, 2012 Report Share Posted June 3, 2012 Any one got pictures or good ideas on were to mount MY fuel pump and fuel filter.I have a Aeromotive fuel pump and filter and its billet but i don't know were to go with this.I thought about on the outside of the frame rail so it can be seen some what and then i thought that was not a good idea.PLease any thoughts on this,i know its not rocket science but i feel stumped. Quote Link to comment
josh817 Posted June 3, 2012 Report Share Posted June 3, 2012 I mounted mine under the passenger side seat, on the outside/underside of the car, on the tranny side of the chassis rail. Have a rubber hose and a filter before the pump going right to the fuel line as it goes through the crossmember/chasis. Really easy to access and remove/replace if needed. Quote Link to comment
ggzilla Posted June 3, 2012 Report Share Posted June 3, 2012 Mine was mounted on the battery shelf bracket thing. Not immediately visibile, but you could see if you looked down past thebattery. Quote Link to comment
datzenmike Posted June 3, 2012 Report Share Posted June 3, 2012 External electric pumps should be located as low and as close to the tank as possible. Pumps can produce almost unlimited pressure but no pump made can suck water vertically more than about 30 feet. Quote Link to comment
mrbigtanker Posted June 3, 2012 Author Report Share Posted June 3, 2012 External electric pumps should be located as low and as close to the tank as possible. Pumps can produce almost unlimited pressure but no pump made can suck water vertically more than about 30 feet. Thanks for the feedback,so do you think outside the frame rail by the fuel tank is a bad idea. Quote Link to comment
datsunrides Posted June 3, 2012 Report Share Posted June 3, 2012 That would seem to be a good spot. It is somewhat "exposed", so a oil pressure cutoff switch would be a good safety feature. No oil presure, no fuel pumping. Mark Quote Link to comment
datzenmike Posted June 3, 2012 Report Share Posted June 3, 2012 It's fine. I would prefer to put on the inside of the frame just for protection. Quote Link to comment
mrbigtanker Posted June 3, 2012 Author Report Share Posted June 3, 2012 Thanks for the input other then it being I guess pretty to look at your right the inside would be the ideal place,I guess are start lining it up. Quote Link to comment
zed Posted June 4, 2012 Report Share Posted June 4, 2012 my spare electric fuel pump came with instructions saying it must be mounted 'within 12 vertical inches' of the fuel tank. Quote Link to comment
