510 rear camber/toe question.
SpooF
  • Replies 5
You can change the rear alignment by raising/lowering the rear.... other than that, nope. You need to slot the crossmember or get the FutoFab kit. If you do any kind of aggressive driving, I highly recommend the FutoFab kit as with a slotted crossmember your alignment just won't hold.
I was having issues with the mounting bolts sliding around, and even went as far as tack welding the washers to the crossmember...... couple months after I did that, I discovered 2 of those tack welds had broke.
The FutoFab Camber - Toe brackets are C&B Brackets. We purchase them from Byron in multiple unit orders. Our prices are the same as what Byron sells them at.
Only benefit of buying from FutoFab is we are in the US so shipping times are shorter and costs are lower to US customers.
Same product, just quicker and cheaper delivery, $15/set in 2-4 days to US customers.
