Rat720 Posted May 25, 2012 Report Share Posted May 25, 2012 Well for some reason I won't learn to stop trading my 720s but I always end up back n one and i think I've found my last. Picked this up about a week ago. It's an 85 720 dually. From what i can tell original dually drivetrain, no badge under hood to help determine that. Has a bed off a 52 Chevy truck. Picked it up running hot and missing like hell. Got home did plugs, way past due cap and rotor, and took the timing from full possible advance at dizzy to where it should be, now runs smooth as could be and no more hot temps. Slave went out on the way home from getting it, luckily wasn't far from parts store so got it thrown on and back rolling n like 30mins. Next problem was the bed was barely even tached together, by the time I was almost done with the 2 hour drive home I had already had to pull over and use c clamps to hold the bed on cuz the horrible welds had broken. Now I'm no master welder by anymeans, just starting out teaching myself honestly, but I've already done some much better welding and the bed is now held together much much better. Plans for now are to finish everything that was done half ass and do my own touches to make it 100% mine. What do you guys think. Also I get to the top of my rpms at around 65-70 in 5th, is this due to low gearing in this rearend. How rare are 720 duallys. Pics will be up very soon. Quote Link to comment
elfirebeasto Posted May 25, 2012 Report Share Posted May 25, 2012 your truck can go 70?! I'm lucky to hit 55 without it bucking like its out of power. Can't wait for pics. I love the way the dually looks. Good luck with your "last" truck. May it be everything you want and more. Quote Link to comment
poor-mans-720 Posted May 27, 2012 Report Share Posted May 27, 2012 I got mixed feeling on the bed... But over all, its sexy .. Like the painted rims... Quote Link to comment
regularJJ Posted May 27, 2012 Report Share Posted May 27, 2012 your truck can go 70?! I'm lucky to hit 55 without it bucking like its out of power. There is something wrong with your 720. I was doing 80 today without overly laboring the engine and all stock equipment. Sweet Datsun, Rat. Definitely like the bed and rims. Quote Link to comment
elfirebeasto Posted May 27, 2012 Report Share Posted May 27, 2012 There is something wrong with your 720. I was doing 80 today without overly laboring the engine and all stock equipment. --sorry quote doesn't seem to work from the phone-- I just took the truck out yesterday, I was easily doing 70. I was gauging from the last time I owned the truck. I guess the guy who owned it between then and now fixed a couple vacuum lines. She runs pretty darn well now. Spins the tires and whatnot. But I think I still need to redo all of the vacuum lines and get my choke fixed cuz ya gotta pump the gas to get it to start. I love thee way that bed looks with the rest of the truck, and the over all paint scheme is pretty cool too. Nice truck! Quote Link to comment
Rat720 Posted May 27, 2012 Author Report Share Posted May 27, 2012 Thanks guys. I've been throwing around the idea of seeing what a simple wood flatbed would look like. One that is just as wide as the frame and exposes the tires. But I really like how the bed looks. Any ideas on the gearing of my rearend? I don't mind the cruising at 60-65 just curious. In the next few days I should have the mini stacks done, can't wait. Quote Link to comment
datzenmike Posted May 27, 2012 Report Share Posted May 27, 2012 If the dual tires are stock it's a Cab/Chassis option. They only came with a 4 speed (could have been changed) a two piece (3 u joint) driveshaft and 4.375 rear gears. Quote Link to comment
Rat720 Posted May 28, 2012 Author Report Share Posted May 28, 2012 So the only gearing that came In the dually was 4.3s datzenmike? Do I have any options for swapping the ring and pinion for better mileage? Quote Link to comment
Rat720 Posted May 28, 2012 Author Report Share Posted May 28, 2012 ??? Anyone know of a ring and pinion swap? Any more opinions on the truck? Will try to get more pics up tomorrow Quote Link to comment
downshift2 Posted May 28, 2012 Report Share Posted May 28, 2012 nice truck man wat part of atl are u at and i think u should give it like a tow truck look it would be the only one in ratsun i thinks if thers not another one out ther lol Quote Link to comment
Rat720 Posted May 29, 2012 Author Report Share Posted May 29, 2012 I'm in gwinnett. You? Quote Link to comment
]2eDeYe Posted May 29, 2012 Report Share Posted May 29, 2012 You should be able to swap any H190 diff from a datsun truck. The tag under the hood usually has the gear ratio listed. Quote Link to comment
downshift2 Posted May 29, 2012 Report Share Posted May 29, 2012 im in gwinnett as well Quote Link to comment
Rat720 Posted May 29, 2012 Author Report Share Posted May 29, 2012 That's the thing there is no tag or sign of there haveing been a tag there. Lol. So I should be able to swap any h190 diff in and keep the dually right? And cool, we should meet up sometime. Quote Link to comment
downshift2 Posted May 29, 2012 Report Share Posted May 29, 2012 yeah we should im close to the snellville area and lilburn Quote Link to comment
metalmonkey47 Posted May 29, 2012 Report Share Posted May 29, 2012 Wooooo more GA truck guys. So I should be able to swap any h190 diff in and keep the dually right? Yup! The H190 truck diff didn't come in many different gear sets though. Look around in the yards through all the 620's and see what the ratio is on the tag under the hood. Quote Link to comment
Rat720 Posted June 3, 2012 Author Report Share Posted June 3, 2012 Ok guys, doing some research, which o shouldve done before asking, ive found I might have the h223b rear axle. With 4.65 ratio. Apparently the h190 doesn't have a removable diff cover? Mine does, with 8 bolts. Quote Link to comment
SHORTDOG Posted June 7, 2012 Report Share Posted June 7, 2012 Hey Rat, Your truck is definitely different but it has that cool look to it! The bed by the way looks more like a 55-59 Chevy (going by the fenders) rather than a 52. How about some interior shots? Quote Link to comment
Rat720 Posted June 13, 2012 Author Report Share Posted June 13, 2012 Update. Tree fell on the bed 3 nights ago. Great sight to wake up to. Not. But building a flatbed to replace. Looks Badass. Still wondering about the rear end info I asked about. No takers? Pics up soon Quote Link to comment
