rAwKStAh! Posted May 9, 2008 Report Share Posted May 9, 2008 will a five speed from a B210 a14 fit on a l16? or should i just swap the l16 for the a14 and 5speed??? Quote Link to comment
ggzilla Posted May 9, 2008 Report Share Posted May 9, 2008 agreed: A-series transmission does not fit L-series engine. The L16 is bigger than A14, a 5-speed is no substitute for more cubic inches. Quote Link to comment
CharlieBucket Posted May 9, 2008 Report Share Posted May 9, 2008 agreed: A-series transmission does not fit L-series engine. The L16 is bigger than A14, a 5-speed is no substitute for more cubic inches. i just ask the same thing in my b210 thread. i think i sorta knew the answer but i really wanted to put a L in my b210 and keep my dogleg. oh well, i am going to keep my a14 i think. i'll go for speed in the 620. Quote Link to comment
Dime Dave Posted May 9, 2008 Report Share Posted May 9, 2008 Guys, Don't rule it out 100%. The A series engine 5 speeds were either 60 or 63 series. The early B210's used a dogleg 63A transmission. These are tha same transmissions that were used in the dogleg HL510 and S110 - 200SX cars in 78-81(?). They used the L20B engine. If your transmission is a 63A, you can swap the bellhousing/forward case section with one from the 510/200SX dogleg transmission and use the B210's existing transmission. I beleive the tail housings are the same 510/200SX to B210, so a direct swap might also be performed. http://wiki.datsun1200.com/index.php/5-Speeds Quote Link to comment
Dime Dave Posted May 9, 2008 Report Share Posted May 9, 2008 Here are some pictures to identify the 63A in a B210. http://datsun1200.com/modules/myalbum/photo.php?lid=13615 http://datsun1200.com/modules/myalbum/photo.php?lid=13612 Also the later Z20 510's (1981) had an again different bellhousing/forward case to acomidate the angle of the Z series engines. (can be used to install a KA engine as well) Quote Link to comment
datsunaholic Posted May 9, 2008 Report Share Posted May 9, 2008 Of course that means actually GETTING a L-series dogleg to begin with, and finding a broken one someone hasn't already recycled isn't easy. The S110 200SX did NOT use a dogleg- it used the F5W71B. Only the S10 200SX ('76-79) used the dogleg. The '79-79 510 also did ('80-81 would have a NAPS-Z bell) and the 810 used a longtail version of the dogleg (front case was the same as the shorttail). Quote Link to comment
mnementh666 Posted May 10, 2008 Report Share Posted May 10, 2008 The S110 200SX did NOT use a doglegCorrect. The S110 (80-82?) used 71B and NAPS-Z engine Of course that means actually GETTING a L-series dogleg to begin with, and finding a broken one someone hasn't already recycled isn't easy.I have one! :D I was about to post to see if someone wants it. My main question: It sound like you want to swap the L16 out, and put an A14 in? Quote Link to comment
DRIVEN Posted May 10, 2008 Report Share Posted May 10, 2008 I didn't see what you were trying to move around. I've run plenty of A and L series stuff. Nissan only put the A series stuff in their smallest cars for a reason - They tend to be a bit on the gutless side (I drive one everyday). I agree with ZILLA, there is no substitute for cubes. L's are great and certainly have more grunt (used to drive one everyday). Plus there are alot more available 5-speed choices. Sounds like an awful lot of work. Maybe you should just give the A series stuff to me.:D Quote Link to comment
