gen4maxima536 Posted May 6, 2008 Report Share Posted May 6, 2008 do all the L and NAPS-Z motors use the same flywheel bolts? i'm doing an auto-> man. swap and i remember reading the flex plate bolts aren't long enough. Quote Link to comment
Z-train Posted May 6, 2008 Report Share Posted May 6, 2008 L & Z motor flywheel bolts interchange but NOT between Auto & stick. Quote Link to comment
gen4maxima536 Posted May 6, 2008 Author Report Share Posted May 6, 2008 alright, thats kinda what i was thinking Quote Link to comment
datzenmike Posted May 6, 2008 Report Share Posted May 6, 2008 Be sure to remove the spacer between the auto flex plate and crank when putting the flywheel on. Quote Link to comment
subedats Posted May 7, 2008 Report Share Posted May 7, 2008 Be sure to remove the spacer between the auto flex plate and crank when putting the flywheel on. yeah i forgot to do that and I striped one of the bolts and broke it off in the crankshaft.. dont ask.. but dont use a 5ft pry bar to try to tighten the bolt....:mad: :( so pissed but I just drilled out the bolt and chipped off the remaining pieces and then retaped and it was fixed. about a day and a half later. Quote Link to comment
datzenmike Posted May 7, 2008 Report Share Posted May 7, 2008 Know how you feel. Back in the early '80s I got an L20B and put it together for my '71. Took a while, and when ready for the flywheel, the crank threads were rusty, never gave it a thought, slapped it on. Months later I was driving a date home and suddenly no power. All the bolts sheared off. I shut it off but it wouldn't re-start, of course. I slipped it into second and used the starter to crank me about three blocks and parked it. First electric 521 in Ontario. I drilled them out with an electric hand drill, oversize tapped them, and some grade 15 bolts. You could see that a few were slightly crooked but what did I know back then right? Quote Link to comment
gen4maxima536 Posted May 8, 2008 Author Report Share Posted May 8, 2008 ok, i'll remember all that. i need to get a pilot bushing also correct? is there anything i need to take out or does that slide right in? Quote Link to comment
datzenmike Posted May 8, 2008 Report Share Posted May 8, 2008 An auto wouldn't have one so pop one in. Tap it lightly to start and put a block of wood over it and hammer it all the way in. Quote Link to comment
