68Datsun510 Posted April 17, 2012 Report Share Posted April 17, 2012 WHats the "preferred" way to eliminate the water flow from the head to the intake manifold on an L motor? Gasket without holes, or tap/thread the manifold and block it with a plug??? Quote Link to comment
Skib Posted April 17, 2012 Report Share Posted April 17, 2012 I plug the manifold 1 Quote Link to comment
banzai510(hainz) Posted April 17, 2012 Report Share Posted April 17, 2012 1/4 inch pipe plug. 1/4 inch is the allen size. go to a good hardware store and theyll gove you the correct tape for it. If you have a stock head with the stock water passage hole all you need to do is run the tap. as the hole is already the correct size or close to it already so no need to hole size it for the tap. my cheat sheet shows 1/4 plug NPT 1/4- 18 NPT use a 7/16 drill bit if needed. If close to 7/16 just use the tap/ Quote Link to comment
datzenmike Posted April 17, 2012 Report Share Posted April 17, 2012 Keep it if possible. It warns up and drives better sooner with it. On really hot days with high under hood temps, or if you have a lot of radiant heat from a header, it actually 'cools' the intake. It keeps the intake air at a more constant temp over a wider range of applications. Quote Link to comment
banzai510(hainz) Posted April 17, 2012 Report Share Posted April 17, 2012 I plugg them if using sidedraft carbs other wise I keep them stock(with a down draft for winter to heat the carb otherwise in cold claimates carb can freeze and ice up) Quote Link to comment
68Datsun510 Posted April 17, 2012 Author Report Share Posted April 17, 2012 It doesn't get particularly cold here, coldest we've EVER had was 16. Ave mid 30's for lows at worst. Im just wanting to avoid the whole, pull the intake, flood the garage with coolant crap. Thinking of just plugging the head holes and be done with it. Quote Link to comment
docbainey Posted April 17, 2012 Report Share Posted April 17, 2012 Plugging the holes in the head is the way to go. If you plug the manifold you can still have water leaks and such. Quote Link to comment
