legitimate_datto_scientist Posted April 16, 2012 Report Share Posted April 16, 2012 so my car has this dumb hose that opens up to the pside floor, ive always assumed it was a detatched piece to my non-op ac, so i never worried about it. so the other day my fan belt hose snaped, i drove it a couple of times before i relized it was gone. it drove warm never hot. anyway, i fixed the belt and now after drving for a few minutes my car starts heating up, then begins dumping coolant out the hose followed by a ton of steam. my first thought is a clogged heater core? maybe i can bypass it? i need my car for work, so im not opposed to a quick temp fix Quote Link to comment
Npdavies. Posted April 16, 2012 Report Share Posted April 16, 2012 I think that hose was probably for your heater core. You can probably just plug it or get a 90 degree pipe and connect the inlet hose to the outlet hose to bypass the heater core. Quote Link to comment
Skib Posted April 16, 2012 Report Share Posted April 16, 2012 heater stuff. you can just loop the lines for now. no more heater that way but theyll be dry haha Quote Link to comment
Spades Posted April 19, 2012 Report Share Posted April 19, 2012 loop the heatercore hoses for now, fix it when you have more time. What often happens is an overheat causes old rubber hoses to finally crack out all the way, or worn out heatercores to give up the ghost, I have witnessed it many times. I would expect the overheat was all that was required for the last bit to give way. When you have time, pull the heater box out and find out what went wrong. Quote Link to comment
metalmonkey47 Posted April 19, 2012 Report Share Posted April 19, 2012 Rather then just looping, just get some bypass caps and plug it completely until you get new heater hoses. Quote Link to comment
datzenmike Posted April 19, 2012 Report Share Posted April 19, 2012 maybe i can bypass it? i need my car for work, so im not opposed to a quick temp fix See the two hoses? One from out the back of the head and one from the lower rad hose area and just above the oil filter? Well, cut the long one as close to the fire wall as you can and hold up above the valve cover. Unscrew the gear clamp on the hose from the head and quickly connect the long hose to the outlet and clamp. This will keep you going while you figure out what to do about the heater. . Quote Link to comment
philcas1987 Posted April 19, 2012 Report Share Posted April 19, 2012 the ratsun mod eh? Quote Link to comment
legitimate_datto_scientist Posted April 30, 2012 Author Report Share Posted April 30, 2012 See the two hoses? One from out the back of the head and one from the lower rad hose area and just above the oil filter? Well, cut the long one as close to the fire wall as you can and hold up above the valve cover. Unscrew the gear clamp on the hose from the head and quickly connect the long hose to the outlet and clamp. This will keep you going while you figure out what to do about the heater. . what i ended up doing. turned out it wasnt the hose, the heater core had cracked. thats an a12 in the pic btw, slightly different then the a14, rad enters on the opposite side shown Quote Link to comment
