DatDoug Posted April 16, 2012 Report Share Posted April 16, 2012 Im wanting to rewire my 74 620 hedlites with relays. Cant find any "How-to" threads. Can anyone direct me or help with this? Quote Link to comment
Drummerboy4as Posted April 16, 2012 Report Share Posted April 16, 2012 Hear ya go :D Get some wire, 12ga should work, get 2 in-line fuses (20-30amp), 2 40amp relays, and a few misc connectors. Wire the 2 in-line fuses to the + post on your starter or battery, run those wires to the #30 terminal on your relays For the low beam relay plug the red/black into terminal #87, run a ground to #85, and split the red wire that's plugged into your old relay plugging one lead into the #86 terminal For the high beam relay plug the red/white wire into terminal #87, red/yellow into #85, the other half of your red wire goes to #86 The red, red/yellow, red/black, and red/white should be the four wires that are plugged into your old relay, you may need to extend them. Hopefully that doesn't just confuse you. I pulled it from an old post when I did it a while back Quote Link to comment
DanielC Posted April 16, 2012 Report Share Posted April 16, 2012 Crude diagram. This diagram is actually for a Ford pickup, but it will work for a 620, I believe. Use this relay from Summit racing. It has two 87 terminals, fewer "Y" splices will be needed to hook up the headlights. Quote Link to comment
DatDoug Posted April 17, 2012 Author Report Share Posted April 17, 2012 AWESOME! Thanks Guys:) Quote Link to comment
banzai510(hainz) Posted April 17, 2012 Report Share Posted April 17, 2012 I would just get a H4 harness and use the stock pass side to trigger the new harness(if you can just get that to work then this will be your low current side. You can get 2 light(2 relays) H4 for the outer lights(leave the stock High inner along) or get the 4 headlamps type (3 relays) about a 20min job to install. putting the main power feed at the starter lug. http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml Quote Link to comment
