newer nissan parts on an old
tavilas
  • Replies 5
You can use the parts from the '88 to convert your truck over to ball joints which will give you instant disc brakes. You will have to either buy my conversion upper control arms to correct the camber/caster issue that you will have or you can build your own. My upper arms (do a search) will allow you to basically bolt everything on. You will also have to upgrade your master cylinder and either redo all your hardlines or get an SAE to metric adapter as the hardbody caliper hoses are metric and your hard lines are SAE.
--you can have your spoon back now... :sneaky:
So you think it is possible ? How about parts of an 88 perhaps I want to convert front drum breaks to disc breaks I got a friend that is sailing the 88 hardbody and I though I could do the convention from it
Your buddy is sailing his '88 hardbody? That will sink! hopefully he's sailing it in fresh water so he won't ruin the parts you want to use.
