kinetisist Posted March 27, 2012 Report Share Posted March 27, 2012 now I know that if I try and shift it it should tell me but the shifter needs alot of work and was really slopy so I had to pull the stick and I need new bushings so where is the best place for the bushings and rubber boots?? also this tranny only has the one number 6 that you can see in the pic and that is it...nothing else thanks pistures posted to photobucket http://photobucket.com/datsun1 Quote Link to comment
datsunfreak Posted March 27, 2012 Report Share Posted March 27, 2012 Can't see a pic? Quote Link to comment
datzenmike Posted March 27, 2012 Report Share Posted March 27, 2012 All sloppy shifters feel like there's a 5th gear but there isn't. Usually. 1200s didn't come with 5 speeds but one could have been swapped in. There are three possible 5 speeds that fit the A series. Two are dogleg shift pattern so is reverse above first or not? Like this? R-2-4 1-3-5 If not do you have... 1-3-? 2-4-R Need a picture of the transmission... http://community.ratsun.net/topic/691-how-to-post-pictures-and-keep-online-photo-albums/ Is it in the car or not? Quote Link to comment
kinetisist Posted March 27, 2012 Author Report Share Posted March 27, 2012 thanks for the help Quote Link to comment
kinetisist Posted March 27, 2012 Author Report Share Posted March 27, 2012 Well the easiest way for me to post pics is to put them in Facebook under David pruitt.. check out the pics under PROJECTS and look for the tranny thanks Quote Link to comment
datzenmike Posted March 27, 2012 Report Share Posted March 27, 2012 I NEVER f/b. So you'll just have to learn a new skill set. I got a Potobucket account and got it on the first try, and hey, I'm no whiz at computers. If you are going to be here asking questions you are going to need to post pictures. Quote Link to comment
KELMO Posted March 30, 2012 Report Share Posted March 30, 2012 the oic I saw looks very much like an A12 4 speed My .02 worth Quote Link to comment
datzenmike Posted March 30, 2012 Report Share Posted March 30, 2012 Rear facing oil drain bung and all small case bolts/ no long ones ... looks like an F4W56 four speed. The FS5W56 drained straight down and had some long bolts holding the case halves together. The 60 series (A and L) had a smooth case without 'waffling'. Definitely not a 63A dogleg 5 speed . Quote Link to comment
TENDRIL Posted March 30, 2012 Report Share Posted March 30, 2012 looks like a 4 speed to me ... check this out http://www.datsunparts.com/Transmission-4-Speed 8.00$ Quote Link to comment
datzenmike Posted March 30, 2012 Report Share Posted March 30, 2012 32855-H1010 (same as 280z/zx, 620, 200sx, A10 on and on) only $3-$4 at the Nissan dealer. Quote Link to comment
kinetisist Posted April 4, 2012 Author Report Share Posted April 4, 2012 thanks for the help .. I was confused because it does not have any markings or other numbers .. came out of a sept1972 model id plate date 1200 Quote Link to comment
