210 to low Posted March 24, 2012 Report Share Posted March 24, 2012 so i just picked up a 72 goon im new to five tens and ratsun but had a twoten till it got rearended so it over heats really bad and i have kno idea why ive tryed eveything i can think of to fix it it has a l16 and four speed tryed taking the thermostat out and made sure its good ..no help back in no change checked the water pump....works great changed head gasket....still over heats bought a aftermarket temp gauge....just tells me what i already kno.. tryed a spare rad i had chiiling in the shop...no change tryed and electric fan...still get way above 190 no smoke really to speak of and no water in my oil... heater core dosent leak either.....im lost on whatt it is or waht to try next any help i would be greatful for thank you... Quote Link to comment
Tristin Posted March 24, 2012 Report Share Posted March 24, 2012 I could think of a few things: 1. You may have some sort of blockage in one of the hoses. You could try flushing out the coolant system with fresh water. 2. You said you made sure the thermostate was good... did you try actually using a new one? Maybe you have a unit with too high of a temp rating. Quote Link to comment
210 to low Posted March 24, 2012 Author Report Share Posted March 24, 2012 tryed running it with out a thremostat havent reaplaced it but i did flush the system with fresh water Quote Link to comment
King-David Posted March 24, 2012 Report Share Posted March 24, 2012 How did you check the water pump? If you haven't done so, you might take it out and see if the impeller spins on the shaft. Also, check the flow of the radiators. You may have two that are partially blocked. I check them by taking off the lower hose and running a hose in the top. A clear rad will take the full force of a house spigot. Good luck. Quote Link to comment
datzenmike Posted March 24, 2012 Report Share Posted March 24, 2012 Does it run hot around town only... or also out on the highway? Does it actually boil over or just read hot? Does it need water added every day, every week? Feel the bottom hose... is it soft? Rev the motor up and look at it.... does it collapse from the suction? Do you have the rad shroud on it? This improves the fan efficiency at lower speeds. Does the fan belt squeak? Quote Link to comment
210 to low Posted March 24, 2012 Author Report Share Posted March 24, 2012 Does it run hot around town only... or also out on the highway? Does it actually boil over or just read hot? Does it need water added every day, every week? Feel the bottom hose... is it soft? Rev the motor up and look at it.... does it collapse from the suction? Do you have the rad shroud on it? This improves the fan efficiency at lower speeds. Does the fan belt squeak? belt dosent squeak none of the hoses seem to be soft will re check tho and no it wont boil over even when it reads around 220 or 230 gets hot everywhere just idling says its hot.....barely looses any water if i dont open the cap whenits cooling down Quote Link to comment
banzai510(hainz) Posted March 24, 2012 Report Share Posted March 24, 2012 ck with a timming light what your timming is. Could be way off. put close to 10deg BTDC. If you did anything to this let us know. Maybe somebody put the dizzy in wrong. olddatsuns.com read it Quote Link to comment
datzenmike Posted March 24, 2012 Report Share Posted March 24, 2012 Well get a hand held digital infra red temperature meter and shoot the thermostat housing. I suspect that it's not running as hot as the meters say. Quote Link to comment
Tristin Posted March 24, 2012 Report Share Posted March 24, 2012 Well get a hand held digital infra red temperature meter and shoot the thermostat housing. I suspect that it's not running as hot as the meters say. That was going to be my next things after reading all the replies. It seems like youve gone through all the items to fix the temp, but it still reads hot. It might just be the gauge. Quote Link to comment
210 to low Posted March 25, 2012 Author Report Share Posted March 25, 2012 sooo now when it idles it idles really really high wont idle down at all still gets hot changed gauges and wraped the tempgauge in a high temp jacket to keep the exhaust heat away from it stilll gets hot wont boil over any ideas? Quote Link to comment
datzenmike Posted March 25, 2012 Report Share Posted March 25, 2012 High idle??? Well what have you done lately that might have affected it? Did you adjust the timing? Quote Link to comment
210 to low Posted March 25, 2012 Author Report Share Posted March 25, 2012 High idle??? Well what have you done lately that might have affected it? Did you adjust the timing? timing is right on at 10 btdc it ides super high or i have to keep feeding it gas theres no in between i dont think ive done anything to affect it after it runs tho when i go to shut it off the radiatior makes a surgeing sound ??? Quote Link to comment
datzenmike Posted March 25, 2012 Report Share Posted March 25, 2012 Your first post didn't mention a high idle so is this something that has just happened? Is the throttle cable too tight and holding it open? Is the idle screw turned up too high? Can you turn it down? Is the choke on? Or is the choke fast idle cam engaged? WD-40 the linkages and work through their full movement to loosen. Hold throttle open when doing this. Take the air filter off and look down the SECONDARY barrel. Is it closed tight?? Use a flash light to see. Quote Link to comment
210 to low Posted March 26, 2012 Author Report Share Posted March 26, 2012 fixed the idle carb was out of wack timing still right on car get to around 210 driving for 15 mins running out of ideas and paitence Quote Link to comment
banzai510(hainz) Posted March 26, 2012 Report Share Posted March 26, 2012 try a 160 deg 54mm stat. drill a small 1/8 in it replace it with a new gasket of coarse. If still out of patience then sell it. Datsun L motors are pretty EZ to work on and if cant handle it Im sure soembody will buy it if nice. Quote Link to comment
Duncan Posted March 27, 2012 Report Share Posted March 27, 2012 When it gets hot, feel across the front of the radiator. If you feel cool spots, the radiator is partially clogged. This has happened to me numerous times over the years. I didn't see any mention of the radiator in this thread, Quote Link to comment
210 to low Posted April 1, 2012 Author Report Share Posted April 1, 2012 THANK YOU ALL FOR YUR HELP! ...but i stil cant keep it from over heating ive double checked with a IR temperature meter its as hot as it reads on the gauge checked the vavles there perfect same with timing idles great now but wont go ten mins at idle with out over heating so short of swaping engines im out of ideas still Quote Link to comment
TENDRIL Posted April 1, 2012 Report Share Posted April 1, 2012 there can be a clog in your heater core, i blasted mine with a hose and sure enuf about a table spoon of crud came out, and that stuff can make it to your rad. and stop half of the rad. from working -tendril Quote Link to comment
datzenmike Posted April 1, 2012 Report Share Posted April 1, 2012 Do you have a clutch fan? If so can you spin the plastic fan blades easily by hand? Do you have a fan shroud? Quote Link to comment
210 to low Posted April 1, 2012 Author Report Share Posted April 1, 2012 Do you have a clutch fan? If so can you spin the plastic fan blades easily by hand? Do you have a fan shroud? stock four blade fan no shroud to speak of there can be a clog in your heater core, i blasted mine with a hose and sure enuf about a table spoon of crud came out, and that stuff can make it to your rad. and stop half of the rad. from working -tendril i flushed the whole system 3 times... Quote Link to comment
datzenmike Posted April 1, 2012 Report Share Posted April 1, 2012 Are the fan blades rigidly mounted to the pulley or do you have the optional clutch attachment? Sorry I may not have been clear, most later motors only have clutch fans. Quote Link to comment
210 to low Posted April 1, 2012 Author Report Share Posted April 1, 2012 Are the fan blades rigidly mounted to the pulley or do you have the optional clutch attachment? Sorry I may not have been clear, most later motors only have clutch fans. oh no its my bad its not a clutch fan its rigidly mounted Quote Link to comment
