nissanprerunnerdavid Posted March 12, 2012 Report Share Posted March 12, 2012 so about a month ago i spun my #4 rod bearing so i was just going to rebuild my motor. then i decided to completly remake the whole truck. inside and out. Uploaded with ImageShack.us starting by teaaring the engine out of there. Uploaded with ImageShack.us got the block back after i honed and resurfaced it Uploaded with ImageShack.us new crank with the new bearings, rebuilt rod and the old pistons Uploaded with ImageShack.us painted the block with high temp paint. it looks grey but its really black Uploaded with ImageShack.us while the head is away i painted the grill and headlight covers. Uploaded with ImageShack.us the center console getting the first of the painting Uploaded with ImageShack.us all the dash pieces about to get sanded and ready to be painted Uploaded with ImageShack.us the dash piece all ready and with the first coat on it Uploaded with ImageShack.us the nightmare of wiring behind the dash. i went through and zip tied everything. Uploaded with ImageShack.us Quote Link to comment
nissanprerunnerdavid Posted March 12, 2012 Author Report Share Posted March 12, 2012 Uploaded with ImageShack.us getting all the llittle dash pieces painted Uploaded with ImageShack.us new head, new pistons, new gasket kit, new oil pump, new timing kit, new everything. my weber 32/36 and header will be here shortly Uploaded with ImageShack.us new head Uploaded with ImageShack.us still have to get my steering wheel but the dash is all in and painted up fresh. Uploaded with ImageShack.us i decided to keep the cheesy wood accents cause i like them haha Uploaded with ImageShack.us Quote Link to comment
poor-mans-720 Posted March 13, 2012 Report Share Posted March 13, 2012 that wood grain is pretty ballin!!! looks good. And the head on that motor... damn... sexy Quote Link to comment
nissanprerunnerdavid Posted March 13, 2012 Author Report Share Posted March 13, 2012 I know!!! You wait and see the Carb and header on the engine. Its gonna look killer. Quote Link to comment
poor-mans-720 Posted March 13, 2012 Report Share Posted March 13, 2012 can't wait to see that new baby... Congrats. Quote Link to comment
nissanprerunnerdavid Posted March 13, 2012 Author Report Share Posted March 13, 2012 Thanks man!! Quote Link to comment
datzenmike Posted March 13, 2012 Report Share Posted March 13, 2012 Did you measure the cylinder wear and taper first? The block could be worn past what stock size pistons and rings can seal. I see a ridge ring at the top of the piston ring travel... BTW the wood grain on the dash isn't cheesy. Quote Link to comment
nissanprerunnerdavid Posted March 14, 2012 Author Report Share Posted March 14, 2012 I did and the are within the stock range and the ring wear just looks bad. It is almost nothing it looks alot worse than it is. And I really like the wood too!!!! Haaha. Quote Link to comment
nissanprerunnerdavid Posted March 18, 2012 Author Report Share Posted March 18, 2012 Does anybody know where to get a oil pump drive gear?? I've been looking for hours now with no luck. Thanks in advance for the help. Quote Link to comment
Skulptr Posted March 18, 2012 Report Share Posted March 18, 2012 Oil pump drive gear? The one driven by the timing chain? Quote Link to comment
datzenmike Posted March 18, 2012 Report Share Posted March 18, 2012 It's also known as the oil pump spindle and it's driven by a worm gear directly from a the crankshaft and just in front of the timing chain sprocket. Quote Link to comment
nissanprerunnerdavid Posted March 18, 2012 Author Report Share Posted March 18, 2012 Yeah that's right!! I just can find any of them on line? Any help? Quote Link to comment
Skulptr Posted March 18, 2012 Report Share Posted March 18, 2012 Do you currently have one? Quote Link to comment
datzenmike Posted March 18, 2012 Report Share Posted March 18, 2012 Where's the one from the motor you have? Quote Link to comment
nissanprerunnerdavid Posted March 18, 2012 Author Report Share Posted March 18, 2012 It was broken. One of the splines was chipped and i need to get a new one to continue on my engine. And I don't have one currently. Quote Link to comment
nissanprerunnerdavid Posted March 18, 2012 Author Report Share Posted March 18, 2012 And I have had no luck on finding one anywhere. Quote Link to comment
Sealik Posted March 19, 2012 Report Share Posted March 19, 2012 And I have had no luck on finding one anywhere. The L and Z oil pump drive/skew gear are the same... Someone has one..... Post in the Wanted 'Ads' I have some....but.... cheaper to get it 'locally' Quote Link to comment
nissanprerunnerdavid Posted March 19, 2012 Author Report Share Posted March 19, 2012 Is the only place to get one a junkyard?? Quote Link to comment
datzenmike Posted March 19, 2012 Report Share Posted March 19, 2012 Yes. Nissan may still have one about $40. All Z20/22/24 spindles are the same. Likely the L20B spindle will fit but it does have a different part number. Quote Link to comment
nissanprerunnerdavid Posted March 19, 2012 Author Report Share Posted March 19, 2012 So should I just call a Nissan dealer?? Quote Link to comment
nissanprerunnerdavid Posted March 19, 2012 Author Report Share Posted March 19, 2012 And i did throw a post in the wanted add. Quote Link to comment
nissanprerunnerdavid Posted March 19, 2012 Author Report Share Posted March 19, 2012 Will the l series work for sure? Quote Link to comment
Sealik Posted March 19, 2012 Report Share Posted March 19, 2012 Will the l series work for sure? I've ran the longer Z24 oil pump spindle with the Z24 dizzy in the L block.....so yes...the 'skew gears' are the same Quote Link to comment
nissanprerunnerdavid Posted March 19, 2012 Author Report Share Posted March 19, 2012 Sweet thank you. Finding one is soooo hard no wrecking yards or dealers sell them I still can't find an y... Quote Link to comment
Lockleaf Posted March 23, 2012 Report Share Posted March 23, 2012 I have one if you are still in need of this gear. I totally bunged up a Z24 crank a couple months ago and when I got another crank it had all the gears etc on it. Not really sure why I left this laying around but I went and found it after I read your thread. You should be honored. I dug through this mess to find this thing for you. :) Here's a couple of pics of it just to be sure. And here is what's left of that stupid crank I messed up, which freed this gear up for you. Oh yeah, officially crank lamped. :thumbup: Anywho, pm me if you still need this thing. It's yours for the cost of shipping. Let my catastrophe be of aid to someone at least. Quote Link to comment
