I have plenty of hair,HOWEVER........
Z-train
I don't need to pull it out at this rate.......... :angry:
Intermittant failure of temp & fuel guage.Based on observations,i thought it was the reg in the temp guage.But magically,they started working and then the temp guage failed as the fuel guage kept working.
Thoughts?
  • Replies 7
If one gauge is working it can't be the fuse. (could be a bad sender or loose wire). Both not working could be fuse or the regulator. I think the 620 regulator just plugs to the back of the gauge cluster and may just need unplug/plug in to clean the contacts.
Ground the Yellow/White sender wire on the front of the thermostat housing the gauge should read full hot if everything working. Be sure wire is firmly on and not corroded from spray.
The tank will have a black ground wire and another (I forget the color) make sure the black one goes to ground. Grounding the other wire fill give a full tank reading. Be sure wires are firmly on and not corroded from spray.
