Dogleg...how to bolt this to this
strang3majik
Ok...I'm sure this is a stupid question...but, I searched and it seems everyone elses bolts up, they just have to space the crossmember down...
But, how does the trans mount bolt to the crossmember? Do I have the wrong mount?
Btw, this is a dogleg 5 speed into a '72 510.
I can make it work by making an adapter...etc, but, I'd rather do it the right way.
  • Replies 9
You should be able to just oblong the 4 holes that bolt crossmember to car,, yours looks very beefy ....your upper trans mount looks different also ,,mine have all been flat ..like this picture but the trans would bolt where plate is..
This is not a 5speed ,,,,,,just showing difference in our brackets your dogleg should bolt right where plate bolts on..
(edit) i have done auto to dogleg swap in the past year, just not this car.
Um I used the auto tranny mount, all of it. You need to run a 1 inch spacer to bring the back of the tranny down. Oh and the dogleg uses some weird T bolts... I lost those and just did something else like a nut up top and a bolt through the rubber part of the mount.
