Radiator Cap lbs??
Toyo Tech
  • Replies 5
If replacing the rad cap get the newer type designed for use with an overflow bottle. This way if it over-pressurizes from heat soak after shutdown is will siphon back in when it cools down. No more topping the rad up every weekend and wondering where it went.
