BOZO Posted February 8, 2012 Report Share Posted February 8, 2012 I recently installed an electric choke Weber progressive carburetor on my 1974 620. I dont think the electric choke is operating properly. The wire running to the choke reads 12 volts, but when the wire is connected to the choke heater, it reads 0 volts. I'm thinking I have a bad choke heater relay, bad connection or wiring. Am I on the right track? Does the choke heater receive a full 12 volts when the ignition is on or does the engine need to be running to energize the field? Currently the engine starts fine and idles when cold and also idles well when up to operating temp when the choke is blocked open. This is a brand new carburetor and everything has adjusted to proper parameters by the tuning instructions. Aside from this choke problem, this is a excellent carburetor. Any help would be appreciated. Quote Link to comment
banzai510(hainz) Posted February 9, 2012 Report Share Posted February 9, 2012 later datsuns had a electric choke like yours so there should be a wire(My 521 truck has wire). wheither a true 12volts I dont know olddatsuns.com should have a drwg for this maybe your not getting 12volts cause the voltage drop your reading from the wrong spot, its almost like a short(just a coil wire)? But think you still read batt voltage Quote Link to comment
datsunaholic Posted February 9, 2012 Report Share Posted February 9, 2012 If you're using the original choke wire, the engine has to be running (and the alternator functioning properly) to get power to the choke. It does not come on with just the key on. The choke relay is engaged when the alternator light goes off, via the voltage regulator. Quote Link to comment
ggzilla Posted February 9, 2012 Report Share Posted February 9, 2012 The electric choke takes 12V. The choke relay takes something different as datsunaholic said it's powered by the alternator. The wire running to the choke reads 12 volts, but when the wire is connected to the choke heater, it reads 0 volts. That is not caused by the choke. You may have a loose/corroded wire, or the relay is cutting out, or something else. Trace the wire back checking the voltage all the way until you find out where it stops. You might find that the relay is not activating. Quote Link to comment
