SyCK Posted February 4, 2012 Report Share Posted February 4, 2012 I searched but didn't come across anything, has anyone done a pull on the rear fenders of a 4 door? Mine are rolled but I need a little more room to go lower since it will rub but I don't want to mess up the factory flare too much and have it look all boo boo. I just need about 1/2" or so of a pull, if anyone has done it can you post pics plz? Thanks :) Quote Link to comment
datsunfreak Posted February 4, 2012 Report Share Posted February 4, 2012 In my personal experience, it's not the fender so much as the hump just inside the fender lip that rubs. Short of cutting that out, not sure what you can do. And since that hump is visible when you open the door... <_< Quote Link to comment
datsunfreak Posted February 4, 2012 Report Share Posted February 4, 2012 I guess what I'm saying is, no matter how much you pull/roll the lips, that hump will always be there. Quote Link to comment
datsunfreak Posted February 4, 2012 Report Share Posted February 4, 2012 15x8 +0 with a 195/50-15 tire. Cleared the fender lip fine, but rubbed on the hump when I hit a bump. :( Quote Link to comment
Laecaon Posted February 4, 2012 Report Share Posted February 4, 2012 Awfully hard with out modifying the body. Merlin is has done it, but you would mess up your paint. Quote Link to comment
SyCK Posted February 4, 2012 Author Report Share Posted February 4, 2012 Thanks for the replies, and yeah I was talking about pulling that bump area out some. I guess I should start looking for some less aggressive wheels at some point if I want to go lower :( Quote Link to comment
datsunfreak Posted February 5, 2012 Report Share Posted February 5, 2012 If you cut out that 90 degree angled hump, and welded in a piece of steel at a 45 degree angle, you could make it work. Won't be easy, but it will be gangsta. :cool: Quote Link to comment
INDY510 Posted February 5, 2012 Report Share Posted February 5, 2012 . That "bump" .... .. seriously DO NOT cut that "bump" ... .. . it's part of your door jam... and you will see the hole even with the door closed Quote Link to comment
datsunfreak Posted February 5, 2012 Report Share Posted February 5, 2012 . That "bump" .... .. seriously DO NOT cut that "bump" ... .. . it's part of your door jam... and you will see the hole even with the door closed Yes, but I think if you weld in a piece of metal at a 45 degree angle to replace it, you won't. ;) Quote Link to comment
SyCK Posted February 5, 2012 Author Report Share Posted February 5, 2012 Shiiiiit... I don't like these wheels enough to go through all of that, maybe if they were something super hard to find and legit.but they're Konigs I'll guess I'll find something else later and deal with it for now, thanks for the replies guys Quote Link to comment
oregondime Posted February 5, 2012 Report Share Posted February 5, 2012 its been cut and re-welded before. ive seen pictures of it. as long as it doesnt mess up the doors edge. im going to do the mod myself.. Quote Link to comment
datsunfreak Posted February 5, 2012 Report Share Posted February 5, 2012 its been cut and re-welded before. ive seen pictures of it. And? :P Quote Link to comment
oregondime Posted February 5, 2012 Report Share Posted February 5, 2012 lol ill get pictures tonight if i remember.. i sleep in the afternoons for work <_< Quote Link to comment
datsunfreak Posted February 5, 2012 Report Share Posted February 5, 2012 i sleep in the afternoons for work <_< Lucky! I wish I had a job that paid me to sleep... <_< Quote Link to comment
jdmdime Posted February 5, 2012 Report Share Posted February 5, 2012 I cut and reshaped the door jam... No biggie I also have the same konigs with the same offsets Quote Link to comment
oregondime Posted February 6, 2012 Report Share Posted February 6, 2012 the bad part about the job is the working at night part, forgot to mention that... this one is from japan.. and i believe this was on ozdat Quote Link to comment
oregondime Posted February 6, 2012 Report Share Posted February 6, 2012 this is that same car from japan, with 16x8 -0 offset http://www.superstreetonline.com/featuredvehicles/sstp_1201_1970_datsun_510/viewall.html Quote Link to comment
ggzilla Posted February 6, 2012 Report Share Posted February 6, 2012 well that looks easy Quote Link to comment
Lee R Posted February 6, 2012 Report Share Posted February 6, 2012 GYUEEEN!!!!! Quote Link to comment
