74datsun710 Posted February 4, 2012 Report Share Posted February 4, 2012 I am wondering if anyone out there has replaced their rear spring bushings on a 1974 710 wagon, and where did you find them if so? I'm having a really hard time finding bushings that fit. I am thinking that i'll have to just replace the entire rear leaf springs just for this problem. If I do decide to replace them any suggestions? I would like to keep it as close to original as possible. (i'm not looking to lower it) Thanks Quote Link to comment
Zeusimo Posted February 4, 2012 Report Share Posted February 4, 2012 Summit Sells Universal Poly Bushings Just Search Your Dimensions, You'll Find Em' Quote Link to comment
Z chopper Posted February 4, 2012 Report Share Posted February 4, 2012 think you have to talk to datzenmike Quote Link to comment
datzenmike Posted February 4, 2012 Report Share Posted February 4, 2012 I got a p/m and may have missread about the bushings. The 710 leaf spring has rubber wrapped around them where the U bolts clamp it to the axle. Probably to absorb road vibration transmitted through the old style nylon cord tires. Todays radials are much softer. I now see he may have meant the ends of the springs. Maybe you can cross reference the number to something else... The fronts are 55047-22900 The lower rears are 55045-A6900 but I doubt the dealer will have them. The same ones are used in the '78-'81 A10 (HL510) Quote Link to comment
ggzilla Posted February 4, 2012 Report Share Posted February 4, 2012 You can still buy 1971 leaf spring bushings from Nissan, so give them a try for the 710 parts. Quote Link to comment
74datsun710 Posted February 4, 2012 Author Report Share Posted February 4, 2012 I got a p/m and may have missread about the bushings. The 710 leaf spring has rubber wrapped around them where the U bolts clamp it to the axle. Probably to absorb road vibration transmitted through the old style nylon cord tires. Todays radials are much softer. I now see he may have meant the ends of the springs. Maybe you can cross reference the number to something else... The fronts are 55047-22900 The lower rears are 55045-A6900 but I doubt the dealer will have them. The same ones are used in the '78-'81 A10 (HL510) Quote Link to comment
74datsun710 Posted February 4, 2012 Author Report Share Posted February 4, 2012 Cool this should help out thanks! Quote Link to comment
