CWhip Posted February 7, 2015 Report Share Posted February 7, 2015 Put a jumper wire between the 2 blue wires in the middle of the harness. The red wires should be for the reverse lights. Quote Link to comment
datzenmike Posted February 7, 2015 Report Share Posted February 7, 2015 That's my guess too. Red/Black stripe are almost always the reverse lamps Quote Link to comment
Sierra Posted February 8, 2015 Author Report Share Posted February 8, 2015 It's alive, it's alive! Thanks datzenmike, PineCone, B210GX and CWhip for responding to my cry of help! I did what you guys suggested and it worked!!!! small fine tuning is needed but the harder part is done. Once everything is working the way it supposed to, I will do a final post in order to summarize what we have done here, so others can use this thread as a guide. Ratsun guys you are awesome! 2 Quote Link to comment
az_rat210 Posted February 25, 2015 Report Share Posted February 25, 2015 Previous post have you jumpering the blue wires, you may just be able to run those via the neutral safety switch on your transmission thus providing a safety interrupt. If you are not getting full power to the starter, then green/black on the tranny plug is always hot and can be used for a starter relay. Quote Link to comment
