85"720 Posted January 24, 2016 Report Share Posted January 24, 2016 So do hardbodies benches fit with little to no modification in a regular cab truck? 1 Quote Link to comment
Lockleaf Posted January 24, 2016 Report Share Posted January 24, 2016 I believe joecool put one in his 720. It might have been rhino13. Look up their 720 build threads. I don't think it took too much. 1 Quote Link to comment
85"720 Posted January 24, 2016 Report Share Posted January 24, 2016 Do the hard bodies come with headrests and a fold down arm rest? 1 Quote Link to comment
DATSAN Posted January 24, 2016 Report Share Posted January 24, 2016 The bench was out of my 720, the buckets out of a Sentra. I couldn't tell you if they came with armrests, but I do believe they had some sort of headrest OEM. old bench on the left; 1 Quote Link to comment
85"720 Posted January 24, 2016 Report Share Posted January 24, 2016 Damm that thing is tore up. I need to stay with the bench 1 Quote Link to comment
Rickie B Posted January 24, 2016 Report Share Posted January 24, 2016 I just pulled 2 seats "excellant shape" out of a 97 Isuzu Rodeo,they were not a direct bolt on ,had to do alot of mods to make them work.1, the sliders are not even ,the inside slider is lower than the outside,so had to shim it up to make level. 2, the rear holes are about 1 in. to short had to drill new holes.3, the front brackets are at the wrong angle so had to bend them to get the bolts in also the Isuzu bolts are larger than the 720 bolts so i used my bolts, all in all wasnt to bad just was far from a direct fit,they are also manual not electric.very well worth the efort,nice addition 1 Quote Link to comment
