77Devon Posted January 13, 2012 Report Share Posted January 13, 2012 Let me start off by saying that this forum has been a tremendous help while working on my 620. This is the first Datsun that I have owned, and I am at the point where I don't know where to go. When I bought it, it was running fine, perhaps rough from sitting a few years, but none the less, it ran. After I got it home I started cleaning it up, changed oil, air filter, spark plugs, the simple stuff. I noticed as I was going through it that some of the hoses were either split, unhooked, or plugged up. Me being the idiot that I am, decided that I should see about getting all of that straitened out, even though it was running fine. So, long story short, it isn't running so hot anymore. The best way that I can describe it is that it will run fine until it is warmed up, then it will sputter randomly when accelerating and die if I don't change the pressure on the gas pedal once it starts to sputter. If I park it and put it in N or P, it idles fine, maybe a bit fast, but it won't die or sputter. The main thing I am wondering is if I have a hose hooked up incorrectly or perhaps some that shouldn't be hooked up or should/shouldn't be plugged. I would really like some pictures of how I should have it all hooked up, I am a novice mechanic and do not have the knowledge to know where everything is, especially when it comes to emissions and vacuum lines. I don't know if maybe someone already has some pictures or would be willing to take some and post them, I would appreciate any help. If this problem doesn't seem like a hose issue, I am more than happy to take tips or advice on how to resolve the issue. Thank you all for the help in the past and on this topic. - Devon Quote Link to comment
datzenmike Posted January 13, 2012 Report Share Posted January 13, 2012 Probably best if you post pictures of what you have. Someone may notice something other than a missing hose. Quote Link to comment
Rob W. Posted January 13, 2012 Report Share Posted January 13, 2012 What he said it may be a sticky choke even sent you a pm I can email you a diagram Quote Link to comment
77Devon Posted January 13, 2012 Author Report Share Posted January 13, 2012 Tried to take some pictures, flash isn't very good, I will take some while its light out tomorrow and post. Quote Link to comment
Rob W. Posted January 13, 2012 Report Share Posted January 13, 2012 Oh and I nearly forgot welcome to Ratsun and PICS OR BAN is the first rule so post up a pic of your truck right away flash or no we don't care we want oics Quote Link to comment
77Devon Posted January 13, 2012 Author Report Share Posted January 13, 2012 http://s580.photobucket.com/albums/ss243/dibs89/ Quote Link to comment
77Devon Posted January 16, 2012 Author Report Share Posted January 16, 2012 Ok, now I am having a more severe issue. I got the hoses connected correctly, put some seafoam carb cleaner in the tank, and went out on the road. After about 2 minutes, it started sputtering on me to the extreme. The only way I could keep it going and make it back was to press the accelerator, let off, press it again, and do this repeatedly. If I just held the accelerator, it would go for a second, then try to cut out. The last time that I tired to pull the carb to clean/rebuild it, I couldn't figure out how to get it all the way out. Does anyone have any instructions or pictures on how to pull the carb? Unless it sounds like it could be anything else. I confirmed that the choke is opening all the way when it is warm, I replaced the fuel filter 2 months ago, and it has new gas in it. Quote Link to comment
screamer510 Posted January 16, 2012 Report Share Posted January 16, 2012 My manual has worked really well for me and my 510. Get one while they last! AMAZON 620 Manual Good luck with getting it running. Is there a diagram under the hood? Quote Link to comment
Rob W. Posted January 16, 2012 Report Share Posted January 16, 2012 yes get a manual while they last. Did you disconnect everything?? Throttle cable included it should just lift off. There is a picture here of mine all the way off maybe it will help. carboff Good luck. Call me if you want I can walk you through it I think I sent my phone # to you... Quote Link to comment
]2eDeYe Posted January 16, 2012 Report Share Posted January 16, 2012 X3 on the manual. Welcome aboard, nice truck :) Quote Link to comment
77Devon Posted January 16, 2012 Author Report Share Posted January 16, 2012 I do have a PDF manual, posted it here as a download a while back. I just got the carb off :D. Going to get a rebuild kit and see how it works. Will keep posted. Here is an updated pic of the bed. Quote Link to comment
kgrantkey Posted January 20, 2012 Report Share Posted January 20, 2012 Ok, now I am having a more severe issue. I got the hoses connected correctly, put some seafoam carb cleaner in the tank, and went out on the road. After about 2 minutes, it started sputtering on me to the extreme. The only way I could keep it going and make it back was to press the accelerator, let off, press it again, and do this repeatedly. If I just held the accelerator, it would go for a second, then try to cut out. The last time that I tired to pull the carb to clean/rebuild it, I couldn't figure out how to get it all the way out. Does anyone have any instructions or pictures on how to pull the carb? Unless it sounds like it could be anything else. I confirmed that the choke is opening all the way when it is warm, I replaced the fuel filter 2 months ago, and it has new gas in it. This is how mine acted when i had fuel pump issues. I've had electric and mechanical on my 620s. A see thru fuel filter before the fuel pump and the sight glass window on front of the carb can help identify if the fuel is getting to the carb. You may have to drive around with the air filter removed to see the window on front of the carb, but if it's happening all the time it would be easy to see. Quote Link to comment
77Devon Posted January 20, 2012 Author Report Share Posted January 20, 2012 One of the first things I did was replace the mechanical pump and put in a clear fuel filter. I just got the carb rebuilt today and will hopefully put it in tomorrow. I will keep everyone posted. Quote Link to comment
