Paradox Posted January 6, 2012 Report Share Posted January 6, 2012 as the title says, i was wondering your guys opinion on if i can get away will a pull and roll on my front fenders or if id be better off just bubble flaring them wheel specs are 13x7 -25 on the fronts with a 205-50-13 The rears i already got to fit so only worried about the fronts... this is on stock 510 front suspention and fenders with a sloted rear subframe currently running -3 degrees of camber and bubble flares.. PICS BELOW Was also wondering what the widest or even my options of rims i could run on my datsun staggered or not, with little to no modification? Current set up on the car now is 13x7 -25mm with 215 50 13 on the front 13x7 -51mm with 215 50 13 on the rears Passenger side Drivers side Quote Link to comment
INDY510 Posted January 6, 2012 Report Share Posted January 6, 2012 . Did you buy NCRMotorsports CA18DET 510???? ...... . are you keeping the motor??? Quote Link to comment
71ka510 Posted January 6, 2012 Report Share Posted January 6, 2012 um pull and roll will most likely not fix that offset,,, thats flares or buy correct offset wheels..... Quote Link to comment
ggzilla Posted January 6, 2012 Report Share Posted January 6, 2012 Rolling fenders only gives less than 1" clearance Pulling them will only give maybe 1.75"??? You need flares for what you got. Quote Link to comment
Paradox Posted January 6, 2012 Author Report Share Posted January 6, 2012 . Did you buy NCRMotorsports CA18DET 510???? ...... . are you keeping the motor??? Yes and Yes Quote Link to comment
Paradox Posted January 6, 2012 Author Report Share Posted January 6, 2012 um pull and roll will most likely not fix that offset,,, thats flares or buy correct offset wheels..... would any of the rims i listed fit better and fix the MEGA POKE i have going on? Quote Link to comment
ggzilla Posted January 6, 2012 Report Share Posted January 6, 2012 measure how much clearance you have between the tire and inside of the suspension (the spring cup). I suspect a zero offset might work better as it would move the tire inside 1 inch compared to a -25 offset. Any more and it would probably hit on the inside. Quote Link to comment
Creepy Cruiser Posted January 6, 2012 Report Share Posted January 6, 2012 Where did you find your 205-50-13s? Quote Link to comment
Paradox Posted January 6, 2012 Author Report Share Posted January 6, 2012 Sorry ment 215-50-13 my bad on the typo Quote Link to comment
EricAE86 Posted February 22, 2012 Report Share Posted February 22, 2012 Where did you get those tires? I need them!! Quote Link to comment
banzai510(hainz) Posted February 22, 2012 Report Share Posted February 22, 2012 Dude since you got stock front struts or going to get 280xz struts later will determine the offset you need. I dont know why people buy around the wheels they have. Just get rid of them and find the correct size wheels you need. Rota RBs are cool and EZ. stock strut 15x7 +25mm works all the way around. If 280zx struts 15x7 +15 I think they have and that works all the way arounds. or Panasport 15x6 +22 and that should fit both. 15s and 510s are made for each other. 13in wheels with a 50 series tire You got to really slam the car down to non drivable height to get it to look right. spend 500$ and get the correct wheels instead of fucking up you car body or spending money to fit 100$ set of wheels. Quote Link to comment
EricAE86 Posted February 23, 2012 Report Share Posted February 23, 2012 Sell me the tires!! Quote Link to comment
EricAE86 Posted February 24, 2012 Report Share Posted February 24, 2012 Bump about the tires? Where did you get them? Quote Link to comment
Paradox Posted February 24, 2012 Author Report Share Posted February 24, 2012 I'm pretty sure I bought the last set in existence lol, I got them on tire rack and every other source I know of has stopped carrying any 13" tires.... hence the reason I joined the band wagon and am now running 15x8 rota grid V's :) Quote Link to comment
EricAE86 Posted February 24, 2012 Report Share Posted February 24, 2012 So what happened with the old ones? Srsly I want. Quote Link to comment
FiveTenzo Posted February 24, 2012 Report Share Posted February 24, 2012 I'm pretty sure I bought the last set in existence lol, I got them on tire rack and every other source I know of has stopped carrying any 13" tires.... hence the reason I joined the band wagon and am now running 15x8 rota grid V's :) pics or it didnt happen Quote Link to comment
Paradox Posted February 25, 2012 Author Report Share Posted February 25, 2012 Hey if you can find an online source that has 215/50-13's in stock id love you, and as for the old set I'm keeping them as spares, sorry 86 :( Quote Link to comment
EricAE86 Posted February 25, 2012 Report Share Posted February 25, 2012 That's cool. I think I remember seeing a set at pep boys when I worked there a couple years ago. Quote Link to comment
NCRmtrsprts510 Posted February 26, 2012 Report Share Posted February 26, 2012 Yeah I bought them from tire rack back in late 2009? Guess they only have the kuhmo slicks now. If i find any company that makes them in that size or a similar size lets say 205/60/13, I will let you guys know. Quote Link to comment
