chilibiskits4 Posted December 9, 2011 Report Share Posted December 9, 2011 if anyone can point me in the right direction in where abouts to start looking for these, that would be great... Link to comment
banzai510(hainz) Posted December 9, 2011 Report Share Posted December 9, 2011 getting confused now. I thought you just needed a clutch change now a 5speed trans?? Link to comment
ggzilla Posted December 9, 2011 Report Share Posted December 9, 2011 Don't be confused. First he need a clutch. When Pumpkin got there, he found the transmission was shot as well. You can use the 210 5-speed in a B210 if you get the 210 matching driveshaft and use a different gearbox crossmember. 1979 210 has a lighter dogleg than the B210 unit. Link to comment
BillM Posted December 10, 2011 Report Share Posted December 10, 2011 I have a good B210 5-speed but I want $400 for it. BillM Link to comment
RedBanner Posted December 10, 2011 Report Share Posted December 10, 2011 I have a good B210 5-speed but I want $400 for it. BillM with drive shaft? Theres more to the story I think, he has a standard pattern 5 speed.Dont know wich one, speedo on right/passenger side Drain plug out the bottom in front of the trans mount. Link to comment
RedBanner Posted December 10, 2011 Report Share Posted December 10, 2011 *And trans mount. Link to comment
datzenmike Posted December 10, 2011 Report Share Posted December 10, 2011 The B-210 had an FS5W63A five speed dogleg option, same as the 200sx L20B transmission but with a different A series bolt pattern. Total over kill strength for the A14/15. The later 210 had a 'lighter' FS5W60L dogleg shift pattern through July '79 when it was changed to a regular shift FS5W60A for the remainder of the 210 production. The FS5W63A would be 26" long the other two I don't know. The FS5W60L and FS5W60A 5 speeds look identical to the F4W60 4 speeds so don't get fooled. Link to comment
BillM Posted December 10, 2011 Report Share Posted December 10, 2011 I don't have a driveshaft or mount, only the transmission Bill Link to comment
RedBanner Posted December 10, 2011 Report Share Posted December 10, 2011 I don't have a driveshaft or mount, only the transmission Bill hes going to need those things to swap it in, would be the way to go if you ask me.But his last post said he needs it going by monday sooo, is a 4 speed out of the question? If its a 60 series the shaft and mounts are the same right? And there every where. Then gather the parts to get it back to 63a, or find a good 60 when you can. Link to comment
ggzilla Posted December 10, 2011 Report Share Posted December 10, 2011 B210 or B310 automatic transmission driveshaft will fit the 63-series manual gearbox. Link to comment
chilibiskits4 Posted December 10, 2011 Author Report Share Posted December 10, 2011 Thanks for all the replies..... upon further investigation by pumkin, not only was my clutch slave cylinder shot, but so was the tranny all of a sudden....I have a fix on not having to have the car by Monday so I still have some time to weigh out my options. Either way, the datto will be down for a few weeks while I reshuffle funds to the other cars....but no worries, with all of your help, she will def be up again in no time. It'll be a 5spd, whether dogleg or standard, she will drive again!!! Link to comment
