Juicebox Posted November 21, 2011 Report Share Posted November 21, 2011 I'm a new member and I've worked on my a couple friend's Datsuns and I have begun to fall in love with them so I'm thinking about taking the plunge into ownership. However, I could use some advice if certain deals are worth it. Here's a Datsun I found on craigslist http://portland.crai...2704054295.html I'm wondering if the tensioner spring is an easy and relatively inexpensive fix, or if it's gonna be a living hell trying to get to it. Also has anyone else attempted to contact the owner? I tried emailing the craigslist email and he hasn't responded and there isn't any other contact information. Quote Link to comment
Eagle_Adam Posted November 21, 2011 Report Share Posted November 21, 2011 good lookn truck and the tensioner spring requires you to remove the entire front cover to replace it. Do-able but ya not the easiest thing on the L motors. Quote Link to comment
Eagle_Adam Posted November 21, 2011 Report Share Posted November 21, 2011 ill give you a freebie - http://community.ratsun.net/topic/36903-i-think-im-losing-the-timing-chain-tensioner/ type this into google - "ratsun - tensioner spring" and read what you find :) Quote Link to comment
datzenmike Posted November 22, 2011 Report Share Posted November 22, 2011 "Needs new tensioner spring for timing chain other wise in very good running condition. It does need work and will need to be towed to a destination. " Let me translate this for you: Needs the tensioner put back in place (or replaced) because I didn't lock the timing chain in place and naturally it popped out. Now the oil pump, distributor, water pump, crank pulley must be removed so that the timing cover will come off to get at it. This one will need replacing because the motor was rotated and squashed the spring. The spring doesn't wear out but the shoe on the end does and the chain can stretch. If the shoe or the left and right chain guides are worn out or the chain stretched then a timing kit is needed to replace these. Now the truck does not run, so you cannot drive it to check the brakes, the shifting of the transmission, the clutch, if the motor smokes/knocks/ leaks/overheats/ will restart (or start in the first place) exhaust leaks, if the alternator charges, heater works, steering/alignment, and what ever else. If this sounds harsh, well it is. Harsher to buy something that has everything wrong with it too. The owner should spend a weekend fixing this otherwise it's no better than one in a wrecking yard. So, it all comes down to how much do you trust the seller. Quote Link to comment
H5WAGON Posted November 22, 2011 Report Share Posted November 22, 2011 This job is more about being messy than difficult. Quote Link to comment
Juicebox Posted November 22, 2011 Author Report Share Posted November 22, 2011 I have been following for about a week and decided to join but, to avoid spamming up the forum, is there a way to get a general idea from someone if a Datsun is worth the time/price? Quote Link to comment
banzai510(hainz) Posted November 22, 2011 Report Share Posted November 22, 2011 Offer 300/400 $for the truck. a tensioner is about 15 bucks and a Felprop fron cover set the same. and your time. If Lazy dont dont worry about it and dont buy it as like the last onwer as he says its running good and just the tensioner. But Really who KNOWS WHATS GOING ON IN THERE . cOULD BE A SHEARED OFF BOLT ON THE CHAIN GUIDES. heres the vid. Only way it can be EZer is If I come over and do it for FREE for you Key is if your a Hardcore Datsun guys others will help when possible. But alot of guys are here today and split due to money issue /women ect no place to keep it at the apartment.........So alot will tell you how to fix it and if motivated we will be able to tell if your worth helping. But most of us can provide INFO to guide you if you have a basic mechanic ability. Quote Link to comment
datzenmike Posted November 22, 2011 Report Share Posted November 22, 2011 I have been following for about a week and decided to join but, to avoid spamming up the forum, is there a way to get a general idea from someone if a Datsun is worth the time/price? Sure, go to the top of the page and click on FORUMS. You can select GENERAL DISCUSSION and hit START NEW TOPIC. Now you have your own thread. Describe your problem. It's easy to give an opinion but better for everyone if you post pictures and a good description of the car in question and any plans for what you want to do with it. http://community.ratsun.net/topic/691-how-to-post-pictures-and-keep-online-photo-albums/ Quote Link to comment
Juicebox Posted November 22, 2011 Author Report Share Posted November 22, 2011 If I get the owner to respond to any of my messages then I'll go for it. I'm not afraid of getting my hands dirty. I love wrenching, it's my addiction. If I know anyone and there is any mechanical work to be done I'm over there as soon as I can. Unfortunately going to college 4 days a week, and working my weekends sucks up most of my time. Quote Link to comment
banzai510(hainz) Posted November 22, 2011 Report Share Posted November 22, 2011 Well you should consider then maybe not getting it. Datsuns break down at the worst time and if you dont have alot of spare time or a spare vehicle this could just end up on the side of the house as it is already Quote Link to comment
Juicebox Posted November 23, 2011 Author Report Share Posted November 23, 2011 I have a daily driver that I keep in top shape, I don't love it but, it gets me from point A to B. I'm really busy right now but, next term I will have less days at school (same amount of credits) and I will be working at Pick n Pull so I'll have access to parts. Quote Link to comment
Juicebox Posted November 30, 2011 Author Report Share Posted November 30, 2011 Good news everyone! The owner of the Datsun I originally posted responded almost immediately as I re emailed him tonight. Gonna probably take a look at it soon. Hopefully this week! Quote Link to comment
