twotoedbandit Posted November 11, 2011 Report Share Posted November 11, 2011 Ok, so I've never dealt with serious valve or piston problems before, so any advice is greatly appreciated. Car is a 78 with an a14. Started it up the other day and it made a horrible noise and was obviously in bad shape. Pulled the valve cover and found a bent pushrod and what appeared to be a bent valve. Crap!!!! So I took the head off this morning and this is what I found..."> "> So, my questions are. 1. Do I need a new head or can this be salvaged? 2. Should I replace the piston as well. There is no scoring on the cylinder wall, which is lucky and you can just barely feel where the piston was tapping. Any input is greatly appreciated!!! My instinct says new piston and a clean head, but I'm really not sure. Thanks in advance guys!! Quote Link to comment
Dguy210 Posted November 11, 2011 Report Share Posted November 11, 2011 If you just want to get the car back on the road, the piston is fine. Honestly, I've run much worse without problems, and the damage looks pretty superficial. I would just clean it up a bit to make sure no little fragments are going to come off, and run it. But, definitely new head time. Quote Link to comment
twotoedbandit Posted November 11, 2011 Author Report Share Posted November 11, 2011 That's what I figured with the head. Crap. Anyone have one they want to part with? How much should I expect to pay for one? Quote Link to comment
ggzilla Posted November 11, 2011 Report Share Posted November 11, 2011 You can fix the head, just fit a new valve seat. But this probably happened because someone "rebuilt" the head. I've never seen a seat come loose except after someone replaced the seat incorrectly. I'd just find another good used head. $50. Quote Link to comment
datzenmike Posted November 11, 2011 Report Share Posted November 11, 2011 I've seen them pop from overheating too. I mean really overheated. But then they may have been 'rebuilt' as well. Quote Link to comment
twotoedbandit Posted November 11, 2011 Author Report Share Posted November 11, 2011 Thanks guys. If I can find a used head I'll probably go that route. Gonba take the valves out later and see how bad it scarred out the seat area and see if I want to bother with replacing the seat. Hopefully I can just find another head. I looked quickly at eBay earlier but the only ones that popped up were like 500 bucks and up. Ouch!! I appreciate the help. You guys are always super helpful. Quote Link to comment
king bee66 Posted November 12, 2011 Report Share Posted November 12, 2011 those ebay prices are criminal. put an ad here in the wanted section Quote Link to comment
twotoedbandit Posted November 12, 2011 Author Report Share Posted November 12, 2011 I'm gonna do that ASAP! Quote Link to comment
ggzilla Posted November 12, 2011 Report Share Posted November 12, 2011 Get one from a wrecking yard. They are common on the west coast if nothing else can be shipped. You can also fit an oversize valve seat. The head just needs to be machine larger, heat the head, freeze the seat and pop it in. Quote Link to comment
twotoedbandit Posted November 12, 2011 Author Report Share Posted November 12, 2011 Yeah, I wish I was on the west coast. You don't many Datsuns here in New Orleans, let alone at the salvage yard. I think I've only seen two others in the 5 years I've been here. Anyway, this is what the seat area looks like..."> So, given the gouging that the seat caused, is it still realistic to fit an oversized seat, or would it be best to just replace the head and move on? I'm going to post in the wanted section for a head right now just in case. Anyone have any other suggestions on where to find one. Good wrecking yard to call or website to check. Probably gonna have to have it shipped, cause I doubt I'll find one in Louisiana! Thanks again guys. Quote Link to comment
ggzilla Posted November 12, 2011 Report Share Posted November 12, 2011 As everyone has said, best to replace the head. And yes, it is realistic to repair this head, except it will cost more money than a good used head. Quote Link to comment
Nicholas7620 Posted November 16, 2011 Report Share Posted November 16, 2011 Get your gaskets on Rock Auto, get a 5% discount code from the Rock Auto Thread on Ratsun, The A14 head is found in many datsun models not just the B210. The part no for your head is 11041-H7202, which is interchangeable. I'm looking. F10 model A14 is identical. Other people here know more than me, some one will find you a head. Quote Link to comment
ggzilla Posted November 16, 2011 Report Share Posted November 16, 2011 A14 was used in these North American Datsuns: 1975-1978 B210 1979-1982 210 (B310) 1976-1978 F10 1979-1981 310 (N10) worldwide it was used in more models. They still make the A15 in the 2011 Nissan Serena. A15 is the same bore and used the same heads as A14 (heads vary by year, model, and country). Quote Link to comment
Nicholas7620 Posted November 16, 2011 Report Share Posted November 16, 2011 I found this on ebay... offer, $100, it's the total head, it could be cracked, The last time he got an offer was in August. http://www.ebay.com/itm/Datsun-b210-310-A14-15-cylinder-head-small-chamber-/180688754071?hash=item2a11e39597&item=180688754071&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr Quote Link to comment
Nicholas7620 Posted November 16, 2011 Report Share Posted November 16, 2011 I found this on ebay... offer, $100, it's the total head, it could be cracked, The last time he got an offer was in August. http://www.ebay.com/itm/Datsun-b210-310-A14-15-cylinder-head-small-chamber-/180688754071?hash=item2a11e39597&item=180688754071&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr I found this today, seller has four nos A14 heads http://portland.craigslist.org/mlt/pts/2705979607.html Quote Link to comment
Austinlwalker Posted November 17, 2011 Report Share Posted November 17, 2011 Yeah, I wish I was on the west coast. You don't many Datsuns here in New Orleans, let alone at the salvage yard. I think I've only seen two others in the 5 years I've been here. Anyway, this is what the seat area looks like..."> So, given the gouging that the seat caused, is it still realistic to fit an oversized seat, or would it be best to just replace the head and move on? I'm going to post in the wanted section for a head right now just in case. Anyone have any other suggestions on where to find one. Good wrecking yard to call or website to check. Probably gonna have to have it shipped, cause I doubt I'll find one in Louisiana! Thanks again guys. hey man I'm right here in baton rouge with a 79 210 sedan. Quote Link to comment
Dguy210 Posted November 17, 2011 Report Share Posted November 17, 2011 I found this today, seller has four nos A14 heads http://portland.crai...2705979607.html I wonder how much he wants for those, would still need quite a bit of money to get them to a usable state. Maybe a group buy or something if someone has an idea what he's asking? Quote Link to comment
Duke_CityR Posted November 17, 2011 Report Share Posted November 17, 2011 there is a 75 210 and an 80 310 in the pick and pull yard near me. I'll try to make some free time this weekend to go see if they still have complete heads in the car. there seems to be a pretty steady supply of these cars here in the northwest. I might have to grab more parts when i find them for people on here. I just figured these cars were pretty common everywhere. If the parts are that rare I shouldn't be passing them up anymore. Quote Link to comment
king bee66 Posted November 17, 2011 Report Share Posted November 17, 2011 I wonder how much he wants for those, would still need quite a bit of money to get them to a usable state. Maybe a group buy or something if someone has an idea what he's asking? he sounds like a dick from his ad. he'll probably have to be talked down a bit once he decides on a price Quote Link to comment
Dguy210 Posted November 17, 2011 Report Share Posted November 17, 2011 he sounds like a dick from his ad. he'll probably have to be talked down a bit once he decides on a price Yeah, I got that vibe also :rolleyes: Quote Link to comment
twotoedbandit Posted November 18, 2011 Author Report Share Posted November 18, 2011 Thanks for all the help guys. I've got a replacement head on the way, and found out my intake manifold had a crack as well, so I tracked down a replacement for that too. Hopefully everything will be here this weekend so I can put her back together. Picked up a gasket kit and new pushrods so I should be all ready to go! I'll let you guys know how it works out. Quote Link to comment
Nicholas7620 Posted November 18, 2011 Report Share Posted November 18, 2011 Yeah, I got that vibe also :rolleyes: I sent him an email asking for part numbers from the heads. I got the following reply. From: "RandD321@aol.com" <RandD321@aol.com>Add to Contacts -------------------------------------------------------------------------------- Nicholas, I would not trust the part numbers that I have, as I am not sure these heads are in the correct Datsun/Nissan boxes. They are in original boxes but may be mixed up. The head casting numbers are on each head. Each head has 2 numbers, they are 880 and 411--H72 and 107 290 and 408 and finally 980 and 406. These fit "A" engines 1200-1300-1400 and 1500 CC engines. Thanks for your interest--------ben http://portland.craigslist.org/mlt/pts/2705979607.html Do you have the part #, the picture is too small to see the part number. Very nice heads you have. Best, -------------------------------------------------------------------------------- This message was remailed to you via: sale-7bnsg-2705979607@craigslist.org If this email is a scam or spam please flag it now: http://www.craigslist.org/flag/?flagCode=31&smtpid=20111116234556Ig_-IK0Q4RGffxYcStfpbw -------------------------------------------------------------------------------- Quote Link to comment
ggzilla Posted November 18, 2011 Report Share Posted November 18, 2011 Glad to hear you have sourced the parts. Be sure to use a torque wrench, as the manifold fasteners are low-torque. If your intake manifold is the kind that attaches to the exhaust manifold, bolt it on the head (to align it) before you tighten the intake-to-manifold bolts. Quote Link to comment
twotoedbandit Posted November 19, 2011 Author Report Share Posted November 19, 2011 Yeah. My intake bolts to the exhaust manifold. Good idea about mounting it to the head first, I wouldn't have tvought of that trick. I've got the service manual for the torque specs so I should be ok there. No packages today so it looks like I'll have to wait till Monday to play with her. Oh well. Quote Link to comment
