Rear main on L20B
metalmonkey47
620 Right?
I Just Changed My Pan Gasket
Yup! '76 620.
What about the pickup tube... if you have a cheery picker just yank the motor. It seems like a ton of work but I found it 100on times easier to do clutch and rear main with the motor OUT... makes oil pan gasket a breeze too.
I would love to, but I have asshole neighbors and a neighborhood covenant that prohibits it. dry.gif
I really want to pull the motor, just to paint the engine bay.
I'm at the point that I just want this truck to be mechanically sound. It's a good start with few problems, and I want to keep it that way, so I'm fixing all of the obvious problems. One of which is oil pan gasket.
Edited by metalmonkey47
  • Replies 27
Just Remove X-Member And Unbolt Passenger Idler Arm
Let Steering Hang (Tie If You Wish)
Plenty Of Clearance
Remove, Clean, Sand, Primer, Paint, Gasket, Sealer, Torque, Some More Unessesary Steps...
While You're Down There Slap On A EFI NapZ Oil Pump :P
